Old 04-13-2014, 11:39 PM   #1
New RV'er
low voltage
I have a wildcat 5th wheel 2004 27RL and have a problem that I have nevr seen before so I'm hoping someone else has. When hooked to a land power I have 110 volts power everywhere needed in the RV. The power in the two outlets in the sleeping area are reading 79 volts. I pulled the plugs and found all is correct. I cannot trace the wiring since it gos up into the ceiling. I checked the fuses they are all good. All other plugs read 110 volts.
Anybody with an idea?
Ken
Kenl
2004 Wildcat 5th Wheel 27RL
2002 F250 V10
Kenl is offline   Reply With Quote
Old 04-14-2014, 04:39 AM   #2
Witch Doctor's Avatar
Ken
where did you measure the voltage at? in the socket or at the terminals attached to the socket? Also do you have GFI in line?
Rockwood #8289 WS 2012
F250 6.0 / Husky 16k
With 4 point leveling system
Old 04-14-2014, 11:07 AM   #3
New RV'er
I checked the socket not the wires. There is no GFI inline.
Kenl
2002 F250 V10
Old 04-14-2014, 11:45 AM   #4
TURBS's Avatar
I think all plug ins are required to be gfci protected in a camper.
My 2005 flagstaff had 8 plug ins with two gfci's to protect 4 and 4.
In other words one gfci protected 4 outlets.
The other gfci protected the othe four.
"Daisey chained together"
TURBS
Sabre owners united!
Old 04-14-2014, 11:45 AM   #5
If I were you I pull it out and check the voltage at the wire. You might just have 2 bad sockets or lose wires. I know on my unit which is not the same I have 7 outlets on 1 15 amp breaker. Also check the GFI as Turbo said. That is a weird problem.
Old 04-14-2014, 01:42 PM   #6
RPAspey's Avatar
Check voltage to ground. If possible, use an extension cord plugged into shore/house as the ground reference. Then put black meter lead into that ground, and red into camper outlet. If still 97 volts, its a hot wire problem. If you get 110-120 volts, then neutral problem or ground-neutral could be reversed somewhere.
2000 Cherokee 31BH, "flipped axles and raised",LEDs, solar, inverter, etc..aka "boondock ready". '07 Tundra 5.7L DC-LB, modded as well.
2000 Cherokee 29BH with 6V batteries, LED lights & 400 watts of solar power, flipped axles and raised. 2007 Tundra 5.7L DC-LB with lots of mods. C-co, 8/158th AVN Maint.
RPAspey is offline   Reply With Quote
Old 04-14-2014, 04:37 PM   #7
wanderingwayner's Avatar
I am trying to remember, but I believe I saw a problem similar when the GFI neutral and line were reversed.
2006 Dodge 3500,5.9 Cummins, Bully Dog GT, PacBrake exhaust brake(soon), SRW, 4x4
2013, Crusader 325 RES.
wanderingwayner is offline   Reply With Quote
Old 04-14-2014, 04:56 PM   #8
Herk7769's Avatar
This sounds like a loose wire to me as well. A loose wire will arc causing carbon between the wire and the socket contacts (screw or Press Knife). That carbon will cause high resistance (voltage drop and heat).
Feel the socket when something is plugged in.
A hot outlet is VERY dangerous.
HAM CALLSIGN - KC3FFW
Old 04-14-2014, 05:21 PM   #9
RPAspey's Avatar
You're right of course, but only when the outlet is under load. The open circuit voltage will be full voltage. I got my money on a neutral problem.
Old 04-14-2014, 06:12 PM   #10
I been waiting to see what the OP found, You got to remember the unit is 10 years old, I'm sure they worked at 1 time. Unless something was added that's a good question.......
voltage
