Old 06-03-2015, 09:36 AM   #1
Main breaker
Should I shut off the main breaker if I am not using the trailer for a few weeks.
VetteJohn is offline   Reply With Quote
Old 06-03-2015, 09:47 AM   #2
Even with the breaker off there will still be drains on the battery. The better solution is to disconnect the battery.
2018 XLR Nitro 36T15
2015 GMC 3500 6.6/Allison
SuicideSaints is offline   Reply With Quote
Old 06-03-2015, 09:48 AM   #3
wmtire's Avatar
Are you connected to 120 volt AC shore power?
If not, then it's irrelevant.
You may want to disconnect the battery however, as it can run down from the small 12 volt DC draws on it from the LP detector and such.
2011 Flagstaff 831 RLBSS
breaker
