Old 06-27-2012, 11:23 AM   #11
Oakman's Avatar
X2 what windrider said.
We camped for years with a 30 amp trailer and the only time we popped the breaker was when my wife turned on the blow dryer while we had the A/C on, the microwave running, and the TV on.
You might consider buying a low wattage travel hair dryer. Many blow dryers use 14 to 16 amps alone. Add in the A/C and a 800 watt toaster while the blow dryer is on and you will pop the breaker every time.
Bob and Joyce
2013 CC Silverback 29RL
2010 Ford F250 XL Crew Cab 6.4 liter diesel
ATU Local 788
Oakman is offline   Reply With Quote
Old 06-27-2012, 11:50 AM   #12
tbritt's Avatar
[QUOTE=MotocrossCamper;215670]I think a common misunderstanding is that "if i can do it at home, I can do it in my rv!" you have to remember that at home almost everything you listed has its own separate breaker to run off of. At the campsite your using one for everything.
I agree with (motocross) we are fultimers, for over 3 years now and do alot of camp hosting in different rv parks and (it worked at home) is a standing statement.be safe!!
2012 GMC 2500 HD
2011 303 RK LaCrosse Luxury Lite
Days camped 2010: 274
2011: 365
2012: 365
tbritt is offline   Reply With Quote
Old 06-27-2012, 12:28 PM   #13
To answer the OP's original question, about popping the 30 amp breaker, here is the answer. The trailer cord and load center is designed to handle the load of the camper. Any extra electrical load may not work. AC, Microwave, water heater on electric, when you add it all up is over 25 amps. Now add a television, and a dvd surround system, and you are at max. If there are many lights on, and the converter is drawing power for that, then you are definitely over 30 amps. We have trouble with some at work popping breakers, and we're not running televisions, other than to test, just refer, water heater, and AC, and all the lights. Of course, in the real world, all the lights should not be on at once, and we don't put batteries in them to make sure the converter will handle the load.
One thought, if you can cook outside, move the electric skillet out there , and use the regular house plug on the pedestal. And as someone mentioned, get a travel hair dryer.
LadyWindrider
2012 Ford F250 ext. Cab 4x4
2002 Jeep Wrangler Sahara
2008 Work and Play 18LT
Old 06-27-2012, 01:06 PM   #14
Digger 47, I agree with Fire Instructor, but would like to add. Being a Retired Firefighter and Electrician, when you say shoreline are you speaking of the one in the park pedestal or the one in you load center? I had a similar issue, but the breaker in the load center in the camper kept tripping. I replace the breaker after doing some math and still had the problem with the new breaker tripping! I found that the breaker for the A/C and 30 amp main in the load center were next to each other. Heat was building up in the confined area causing the main to trip. I mover the A/C breaker down two spaces away from the 30 amp main and have not had an issue since. But if the park supply is tripping than Fire Instructor is right on! Hope I didn't muddy an water. Be safe!
2011 Powerstroke-Wildcat is offline   Reply With Quote
Old 07-17-2012, 06:52 PM   #15
VinceU's Avatar
Very good observation! If not applicable here, works for others.
Old 07-17-2012, 07:34 PM   #16
My new V-Lite pops the breaker if the AC and Microwave are run together. In my mind it's stupid I have to turn off the AC to make a bag of popcorn.
Carr, Brenda, Hannah, Callie and Sammy. An F350, a 30WRLTSA, a couple of scooters, and little precious family time. We camp, we ride, we love.
beanoil is offline   Reply With Quote
Old 07-17-2012, 07:36 PM   #17
TURBS's Avatar
What are you plugged into when this happens? Home? Cg? 15 amp household plug in? 30 amp? Are using extension cord?
Here's the deal.
A/c starting amps 15-18 amps
A/c running amps 12-14
Average microwave amps 12-15
Converter amp 3-8
30 amp service to camper.
Math isn't hard here
That's not including if hw heater is running or tv is on.
Old 07-17-2012, 09:19 PM   #18
TURBS's Avatar
read this and add up the amps .
normal appliance amp draws
Old 07-18-2012, 11:28 AM   #19
digger47's Avatar
Wildcat - Shoreline power from the RV site. Have not had an issue with the breakers in the MH. Now that I know this is normal, wife and I reviewed our amp usage and have made adjustments. Thanks for all the input and help.
digger47 is offline   Reply With Quote
breaker, led pad
