Originally Posted by Casey r
I thought about doing the same but I noticed on the the truck side of my 7 way one of the terminals is makes BU light. I think it was the center terminal. Have not looked to see where my 7 way enters my 5th wheel yet to find the cord and see if it has the wire tied in. That’s a some day project.
The center pin on a 7-way plug has two purposes. It's primary use is to supply power to the 12 volt camper system. It is mostoften wired to go off with the TV ignition. It can be wired as a backup light feed if not supplying power to the camper and wired to the reverse switch. It could still be done, but the following would be the best option.
What I would suggest is to run a separate plug from the TV backup light circuit (at the tail lights). Use a 4-pin trailer wiring harness plug between the TV and TT. Then run a line to the rear of the TT to LED lights. You would not need a separate switch. They would only come on when the TV is in reverse. As the TV has a ground to the TT, it would only take the one (positive) wire. A short ground from the TT backup lights to a good TT grounding point will eliminate the need for a full run ground. The entire trailer chassis is a ground.
