Is there any reason not to use this breaker with a manual disconnect/reset as my main breaker and when needed as a battery disconnect? I plan on putting it inside the front pass through which is about a foot away from where the current main battery breaker is.
The trailer currently has 6 gauge wire and an 80 amp self-resetting breaker about 2 feet off the battery (first thing the battery cable goes to).
I'm changing all the 6ga wiring to 2ga which can handle 200amps, so the 150amp breaker is appropriate and I'm not over fusing the line. I will be adding another foot or so to the first part of the cable to move this inside the compartment vs where the existing self-resetting breaker currently is (and is wide open to the rain and weather). I'm also thinking of keeping an 80amp self-resetting breaker in the circuit and this will be my "fail safe" catastrophic breaker and a disconnect. Or would I be better off to just use say a 100amp breaker like this one and let it serve double duty?
I wanted to put in a disconnect switch for the odd time I need to kill the DC and this is easier than unscrewing the battery cable when I need to kill the DC. I'm putting it inside the front pass through for ease of access and longevity of the component (yes, it is marine grade and 100% waterproof), plus I can lock it up to keep the grandkid from being tempted to play with the switch, etc...
I've seen threads where people put in marine disconnect switches, but they were just that, the switch. I have not seen one where these type of breaker/switches were used. We use them all the time in boats and both of my boats have one as a disconnect and DC main breaker.
If you are not familiar with these, you push the red button in, and it manually opens the breaker contacts, dropping the yellow bar downward. To reset, just push the yellow bar back up. They are made to be used as a switch also.
