Old 10-17-2013, 10:06 AM   #31
wmtire's Avatar
Originally Posted by Zhanna View Post
TT plugged in = microwave works. So it is getting power from the plug.
So somehow, the battery seems to have died? I think I'm confused?
Zhanna, the battery is 12 volts and powers the things that work off of 12 volts DC (ie slides, lights, furnace, propane leak detector) etc........ it works like your vehicle would.
Your television, microwave, outlets, and air-conditioner ONLY work off of 120 volts AC power......like your house would. If you are not plugged into a form of 120 volt AC shore power, you cannot use the four things aforementioned in your trailer..................but can everything else that is 12 volt because you have a battery.
Since you have two totally different power sources needed for your travel trailer.................they added what is called a converter. This converter will take 120 volts AC and convert it to 12 volts DC to power the 12 volt things instead of the battery. So, when your are plugged into an electrical outlet, the 120 volt stuff is powered.... and thru the converter, the 12 volt stuff is powered.
If you are not hooked into 120 volts AC power, then the converter doesn't work...thus all the 12 volt stuff runs purely off of the battery.
One more function of the converter is to actually recharge your battery when you are plugged into 120 volts AC power.
If for some reason the converter is not working properly, even though you are plugged into 120 volts AC, the converter is not providing power to the 12 volt stuff, but instead your battery is. Your battery has most likely run itself down, because the converter isn't recharging it.
You said your fridge was working off of propane. Even the fridge needs 12 vol DC power to run the control panel for it. If the converter isn't providing the power, the battery is...and is thus running down.
This may explain it better:
http://rvservices.koa.com/rvinformat...lectricity.asp
http://rveducation101.com/articles/RVConverters.pdf
2011 Flagstaff 831 RLBSS
Iíve lost my scapegoat.
Old 10-17-2013, 10:06 AM   #32
By the way, you can find that trouble shooting guide, along with the manuals for several different Converter models, in the FRF Library. Here's a link to that guide: http://www.forestriverforums.com/for...?do=file&id=24
Old 10-17-2013, 10:19 AM   #33
Zhanna's Avatar
OK. I went out and disconnected the negative terminal on the battery. The horrid beep stopped. I went inside to check the breakers again. The breaker labeled CONV is a double 15 and was on. I switched it to off and the beep came on. I turned it back to on and the beep stopped. So I left the battery disconnected and came back here.
Thanks for the links, I'll go check them out. Is changing out the converter something I could do, or should I wait for hubby?
Zhanna is offline   Reply With Quote
Old 10-17-2013, 10:19 AM   #34
If it's not just a fuse/breaker, I would suggest that you contact a mobile RV mechanic. They might be able to get you on the road for your weekend. (That's not likely to happen with a dealer. I suspect your nearby Camping World wouldn't be fast enough either but you could check.)
Old 10-17-2013, 10:26 AM   #35
I turned it back to on and the beep stopped. So I left the battery disconnected and came back here. Thanks for the links, I'll go check them out. Is changing out the converter something I could do, or should I wait for hubby?
Do you have lights in the RV now (with the battery disconnected)? If so, the converter is working at least to some extent (and it's starting to sound like a bad/shorted battery). I still think you need to check those reverse-polarity fuses on the Converter.
No, I don't think that's something you could do yourself, and certainly not without doing the trouble-shooting steps first.
Old 10-17-2013, 10:32 AM   #36
Zhanna's Avatar
No lights. I don't know how to check the reverse-polarity thingy. I'm thinking it must be the converter. The TT is a 2007, so that has to be it.
Also, should I turn the fridge off?
Old 10-17-2013, 10:36 AM   #37
Zhanna's Avatar
I turned the fridge off.
Old 10-17-2013, 10:44 AM   #38
If your hubby has a battery charger laying around somewhere, you might put the charger on the battery (with the wire disconnected as you have it now). If you can get the battery charged, you can just do a quasi-boondock camping experience this weekend where you just have to conserve battery power. Heck, even take that battery charger with you and you probably won't even have to do that "conserve" part.
Old 10-17-2013, 10:53 AM   #39
TURBS's Avatar
Wow this thread has exploded!
If indeed the converter is bad , there easy to replace.
Here's one removed from a wfco distribution center.
5 minute removal.
My question is she said fridge was on propane but it must have been on 110v as the propane option needs 12v to run the circuit board.... does 110v require 12v to run the circuit board?
Turbs
Old 10-17-2013, 11:01 AM   #40
Turbs
On my RV it has to have the 12v too. Not sure if that was true in 2007 and on that model.
