Old 10-17-2013, 08:46 AM   #1
Zhanna's Avatar
Unhappy Massive, major PANIC!!!
I hate to be an emotional, irrational female, but I'm in full-on panic mode right now!!! Like, I almost had a panic attack!
This past Sunday, we went out to the travel trailer to make sure everything was working properly, as we're going to take it out this weekend. We are planning on dry camping, so we made sure the water pump was working, all the lights, slide, etc. Just everything. It all was working just fine. We even got a new battery, just to be safe.
So yesterday, I went out to put sheets on the bed, turn on the fridge, etc. Again, everything seemed fine. Lights work, etc.
This morning, as I was going out to walk the dog, I hear this horrendous, high-pitched, constant beep. The last time the trailer made that noise, the battery was dead. So I go out there. The slide won't open, the lights won't come on, nothing! We have the trailer plugged into the electric outlet. Why is this happening?!?!? We're supposed to leave at 8:00 tomorrow morning! I am FREAKING out!!!!
Hubby is at work till 5 p.m. today. I have no idea what to do! Somebody please help me!
Zhanna is offline   Reply With Quote
Old 10-17-2013, 08:52 AM   #2
2013 Berkshire 390 BH-60
Jersey Guy's Avatar
Could be something as simple as the battery you put in not being connected properly. Check the connections on the terminals.
Mike
2013 Berkshire 390BH-60
Jersey Guy is offline   Reply With Quote
Old 10-17-2013, 08:52 AM   #3
iceblaze580's Avatar
Sounds to me you have a dead battery I would plug the trailer in or charge the battery
iceblaze580 is offline   Reply With Quote
Old 10-17-2013, 08:54 AM   #4
wmtire's Avatar
Zhanna, when did you put a new battery in, was it before or after the tests you said ya did? The reason I say this, is it's possible the new battery has problems or the wires to it were crossed (very common thing to happen) when installing it.
EDIT: Jersey Guy already pointed this out. I type too slow. LOL
I do need to add that some converters have a reverse polarity fuse that blows when you do hook the battery up backwards.....even if you realize your mistake and fix the wires, the fuse is still blown and will have to be replaced....before the converter will charge the battery when plugged into shore power.
I kind of suspect this has happened.
2011 Flagstaff 831 RLBSS
Iíve lost my scapegoat.
Old 10-17-2013, 08:54 AM   #5
Zhanna's Avatar
The trailer IS plugged in! That's why I don't understand what's going on!
Old 10-17-2013, 08:56 AM   #6
Zhanna's Avatar
New battery before all the testing.
Old 10-17-2013, 08:57 AM   #7
raspivey's Avatar
Where, exactly, is the beep coming from?
Old 10-17-2013, 08:59 AM   #8
Zhanna's Avatar
I THINK it's coming from the breaker box. It's coming from that little area below the fridge. I don't know what to call it.
Old 10-17-2013, 08:59 AM   #9
rskrbina's Avatar
I might recheck ALL the connections on the new battery install. Also fuses, inline fuses in the travel trailer etc. Check that a breaker in your house panel hasn't been tripped that supplies power to you tt. Try to eliminate all the easy things before you start thinking power inverter. I hope this helps.
Rudy and Jenny
2014 Flagstaff V-Lite 28WRBS
2013 F-150 Eco-boost 3.55
rskrbina is offline   Reply With Quote
Old 10-17-2013, 09:00 AM   #10
Just a theory, I am no expert.
I think the propane detector requires 12v
So, If the battery disconnect switch was "on", then the battery wouldn't charge, even if plugged in. so battery could have drained, setting off the propane detector due to low voltage.
Check the battery disconnect switch if you have one???
2013 Rockwood Mini 2503S
2011 Chevrolet Silverado 1500 5.3L
Bryan2503S is offline   Reply With Quote
