Master Light Switch Problem
I have a 2017 Forest River VIBE. Full disclosure: I should begin this post by stating that my electrical knowledge has come by trial and error over the years
small shocks with each step along the way.
Towards the end of our first long trip (5,000 miles - 6 weeks) the master light switch stopped working. Normally when the switch is turned on a group of about 8 interior lights all turn on. Now, the lights do not turn on at the master switch. However, each of the individual lights turn on manually. I am currently plugged into the house 120v with an extension cord. I have done the following:
1. Checked all the breakers and fuses. All ok.
2. Put the volt meter on the two lines going into the back of the switch. It showed power.
3. My thoughts at this point is that possibly the switch has gone bad. So, I uninstalled the switch. I assumed that if I directly connected the wires (bypassing the switch) all the lights would go on. Bad assumption?
they still do not all go on. However, they do still go on individually. New assumption
maybe the switch is not bad.
At this point Im wondering if the trailer bouncing loosened a wire is loose at some point in the series (maybe at the first point, where ever that is) causing the lights not to turn on.
Before I begin dismantling lights I am hoping for suggestions. All I know to do is look for a loose wire. I have attached a picture of the panel in case that would be of any help. Thank you in advance for your suggestions.
