Old 03-26-2014, 08:09 PM   #1
maximum wattage for Rockwood Mini Lite duplex outlets
I'm a newbie, first time owner of an RV, in my case a 2014 Rockwood Mini Lite 1901. I just brought it home. I haven't found in the Rockwood owner's manual an answer to my question . . . what is the recommended maximum wattage of any electrical device plugged into one of the three duplex outlets in the 1901 when operating off the 30 amp exterior power source?
I'm no electrical whiz, but I looked at conversion tables online. With 110 Volts and 30 amps input, the 1901's system is theoretically capable of handling 3300 watts. But what is the recommended practical limit?
Computers, printers don't have much of a draw, but hair dryers, electric skillets, and the like, are a different matter. That's where my question comes from.
Any help, advice would be welcome!
maxv is offline   Reply With Quote
Old 03-26-2014, 08:18 PM   #2
bob213's Avatar
I'm guessing you will throw a breaker at about 28 watts.
AC,electric WH and microwave will usually overload it.(keep in mind what runs in the background like the converter and your refrig. if on elec.)
bob213 is offline   Reply With Quote
Old 03-26-2014, 08:27 PM   #3
GlacierGus's Avatar
maxv, welcome to the forum and welcome to the world of Mini Lites! Come back here often, lots to learn.
2013 Rockwood Mini Lite 2109S
2006 Dodge Durango Hemi 5.7
Equal-i-zer WDH
GlacierGus is offline   Reply With Quote
Old 03-27-2014, 01:05 PM   #4
Thanks Bob. I hope you mean that I'd trip a breaker if the AC, electric WH and microwave were all operating at once.
28 watts doesn't sound like much. I've got a standard 3/8" plug-in drill that draws 3.3 amps which, operating on a 110 circuit, uses 363 watts!
Old 03-27-2014, 01:16 PM   #5
RPAspey's Avatar
Just look at the breaker for that outlet. Likely it's gonna be 15 amps. For that circuit, its going to be maxed out at that. I'm not sure why you're looking for individual outlet wattage. Most commercially made devices for the home consumer will have a 15a plug. Are you looking to power something unique?
Basically add up your parasitic current draw (water heater, converter, fridge element, etc) subtract that from 30amps (3600 watts) and that's about what you have to use.
2000 Cherokee 31BH, "flipped axles and raised",LEDs, solar, inverter, etc..aka "boondock ready". '07 Tundra 5.7L DC-LB, modded as well.
2000 Cherokee 29BH with 6V batteries, LED lights & 400 watts of solar power, flipped axles and raised. 2007 Tundra 5.7L DC-LB with lots of mods. C-co, 8/158th AVN Maint.
RPAspey is offline   Reply With Quote
Old 03-27-2014, 01:19 PM   #6
Think he meant 28 amps. Yes, the A/C, H/W and microwave is too much. My rule of thumb is run H/W on gas if A/C is operating. In my trailer:
Fridg 5 amps
A/C 13 amps
Microwave 10 amps
Elect H/W 11 amps
Converter 4 amps
Any one circuit shouldn't exceed 15 amps. Be careful with the hair dryer when running the A/C as well. My wife always asks me first if it is OK to use the hair dryer.
2011 Flagstaff 831FKBSS
2010 F250 4X4 5.4L 3.73 LS
EQUALIZER E4 1200/12000
Old 03-27-2014, 01:25 PM   #7
TURBS's Avatar
Heres all your numbers.
normal appliance amp draws
TURBS
Sabre owners united!
Old 03-27-2014, 02:23 PM   #8
bob213's Avatar
Yes sorry...meant to say amps.
Old 03-27-2014, 06:43 PM   #9
Thanks!!
Thank you all. The replies I've received are most helpful. I wasn't thinking of any exotic appliance. The hair dryer and electric skillet were the ones that raised the question for me, knowing that both pull some juice.
As I said, I'm brand new to RV'ing and to this forum, but am looking forward to both. One of these days I'll be able to answer questions, you betcha. Thanks again.
Old 03-27-2014, 07:05 PM   #10
davel1971's Avatar
you'll learn how much you can get away with running. Part of the learning curve. Not worth wasting time doing math. Just try it and see what you can get away with. Worst you can do is have to reset a breaker. That's what they are designed for.
David & Lynn
rockwood
