I would check under the slide that does not work to ensure that the ac cable under the slide did not get pinched or cut by the slide. Of course you will have to replace the AC entrance cable plug. I have had this happen to me a couple of times over the years the plug will get dirty and corroded and if you do not clean them off they will not make a good contact with the pedestal thus causing voltage drop and heat and with a high load like the air conditioner the plug will melt. Just make sure all the input connections are clean and tight.
Chuck & Sandra
Engineer/Teacher
2010 F350 CC 6.4
2015 Prime Time Sanibel 3601
