Originally Posted by kgriff5667
How is the charging? Do you charge batteries using solar panel or charge while traveling I do seem to have a slight problem with the lion batteries. Sometimes they charge quickly and sometimes they take much longer, even on shore power.
What kind of converter/charger are you using.
Battleborn offers their batteries as "drop in replacements" and says you can use the same charging equipment as for lead acid batteries but also state that the old equipment may not charge them fully, or as fast.
I just made the changeover to LiFePo and found out quick that if you want to charge them fast and totally full a charger that can maintain a 14.6 charge voltage is necessary. If you have a Progressive Dynamics with Charge Wizard and Pendant you can merely push the button on the Pendant and force it into Boost Mode which is 14.6 volts.
To charge from your vehicle while underway it will most require the addition of a Redarc, Sterling, or Renogy DC-DC Inverter or also known as a battery to battery charger.
The LiFePo batteries need more voltage to charge both quickly and completely (along with the higher current the voltage forces in). If using solar, current will be limited to the amount of sun available.
At first I resisted changing to Lithium but one day I just said "blank" it and went the whole way. A Lithium charger from Progressive Dynamics, a DC-DC charger from Renogy, and a MPPT smart solar controller from Victron to take the power from my "Frankensteined" solar suitcase (160 watt total output from Komaes).
Yes, it was relatively expensive but I won't be buying any more batteries or worrying about whether or not the furnace will run all night when camping in freezing weather. In comparison it was cheaper than a week long cruise in the Caribbean (and will certainly last longer
2023 f-150 SCREW XLT 3.5 Ecoboost (The result of a $68,000 oil change
