Old 05-01-2013, 06:32 PM   #1
Himcules's Avatar
mod: adding 50 amp outlet to the house
got the parts from local home depot and lowes:
- 6 gauge 4 wire bundle, 8 feet.
- 50 amp double throw breaker for my eaton cutler/hammer panel on the house
- 50 amp NEMA 14-50R outlet box
got a 50 amp 30 feet extension cord from camping world on sale from their outlet section
debating if i remove the 30 amp NEMA TT-30R i put in last year for my old jayco class c. i won't need to use this ever again and if i needed to ever use the 30 amp cord, i could use the adapter from the 50amp 14-50R to TT-30R dog bone. hmmm...
too hot this afternoon to do it. will add it tomorrow morning
himcules (10x stronger than hercules)
2013 Forest River Berkshire 390BH-60
ex 2007 Jayco Greyhawk 31SS
Himcules is offline   Reply With Quote
Old 05-01-2013, 07:54 PM   #2
Twisty's Avatar
Cool!
I'd like to do a 30 amp run.
I would need to pull a permit, have a licensed elec. do it and then get an inspection.
Not worth the $$ to me.
FOR SALE 2014 BOSS 6.2L F350
2012 Surveyor SV264
NW Oregon
Twisty is offline   Reply With Quote
Old 05-01-2013, 08:29 PM   #3
Himcules's Avatar
you just need the permit. no lic'ed electrician is needed if you know what you are doing. inspector is only looking for correct breaker, correct wire size, correct wiring. easy as pie to pass the inspection.
Old 05-01-2013, 08:30 PM   #4
Engineer of Crazy Train
ChooChooMan74's Avatar
What I did, I ran 10/3 w gnd. Extra conductor in case I get a 50 amp unit. I will change the breaker to a double and outlet to a 50 amp outlet. But it will only be 30 amp 220. I don't for see needing full 50 amp 220 at the house.
TV - 2015 Ram Truck EcoDiesel
TT - 2015 Rockwood Roo 183
Locomotive Engineer
Nights Camping --- 2015 - 19 Camped | Winterized -- 2014 -18
Come read my Camping Blogs
ChooChooMan74 is offline   Reply With Quote
Old 05-01-2013, 08:33 PM   #5
Himcules's Avatar
10 gauge is not sufficient for 50 amp. minimum per code here is 8 gauge.
10 gauge is fine for 30 amp service tho so you are fine. per code here, 30 amp only requires 12 gauge . i ran 10 gauge as well when i did my 30 amp tt-30r outlet.
Old 05-01-2013, 09:56 PM   #6
That is what I said. 30 amp. If anyone is using 50 amp 220 at home, then wow. 30 amp breaker, and wire rated at 30 amps.
Locomotive Engineer
Old 05-01-2013, 10:05 PM   #7
Iggy's Avatar
I have a motrohome with a 50 amp plug but all I have or need at the house is 30 amp. Why waste the money for a 50 amp ciruit unless you plan on living in it with both AC units running and everything else.
I use a 30 amp to 50 amp convertor plug which slips the 30 amp to the 2 hot wires to the rig. That's all I need to get the refrigerator running and charge the batteries before the trip.
Good information but no need for permits and inspections as long as you know a little about the electric code and electricity. If not yes you need to find a qualified electrian and pay him $150 plus parts.
Old 05-01-2013, 10:30 PM   #8
fast murray's Avatar
I understand that its already in but why not just run 8-3wg instead of 10-3wg and have the correct wire for 50 amps?
2004 Wildcat 28BH
2012 Ram 2500 CCSB 6.7CTD
fast murray is offline   Reply With Quote
Old 05-01-2013, 10:32 PM   #9
12 gauge wire is not big enough for a 30 amp circuit. Not sure where your code comes from the NEC has max overcurrent protection for a 12 ga. branch circuit at 20 amps.
2004 Wildcat 28BH
Old 05-01-2013, 10:45 PM   #10
Himcules's Avatar
i questioned that too, but the inspector said it should be 12 gauge before i bought the parts. i installed 10 gauge and he passed it.
the outlet box is located next to the panel. the wire length is literally 16 inches.
since i have extra 6 gauge, i could just replace it while i'm at it... or remove it since i really don't need it... hmmm...
it's extremely hot here in the summer so when i'm loading the coach, i run both a/c's. 30 amps is not going to be able to power both a/c's, the charger and the fridge...
