Old 08-17-2015, 11:24 PM   #1
fr1rd831's Avatar
Mounting solar panel without drilling holes in the roof
I am considering using the following mounts to attached a solar panel to my Class C RV with a rubber roof.
Instapark ZJ03W Drill-free Solar Panel Roof Corner Mount Rack Bracket Kit NEW
And
Instapark ZJ04W Drill-free Solar Panel Roof Mount Rack Rail Bracket Support Kit
Example installation from
RV solar system DIY
Question I have is with a rubber roof that is basically glued down, is their any issues with gluing these mounts to the rubber roof?
Will this work on a rubber roof?
Ray and Maria
Lincoln CA
Our Forest River Gallery & Family Photo's link
fr1rd831 is offline   Reply With Quote
Old 09-20-2015, 12:13 AM   #2
DodgeNerd85's Avatar
Did you use these mounts ?
2015 Stealth 2812G
2012 3500 Mega Cab DRW
ISR Series SuperGlide 16K
GO NAVY
DodgeNerd85 is offline   Reply With Quote
Old 09-20-2015, 12:37 AM   #3
Bluepill's Avatar
Amazon is your friend. Reviews here:
http://www.amazon.com/Instapark%C2%A.../dp/B008GYDT50
2008 Itasca Meridian 37H
Old 09-25-2015, 07:26 AM   #4
Arrow Going Bonkers - Solar
Going bonkers here. I am thinking of mounting the solar panels above my windows on a hinge to gain two objectives in one installation. They would serve as awnings over the windows and also tilt toward the sun to maximize the charge to the batteries. Has anyone done so? Problems? Victories?
Rich H.
[/SIGPIC]
Solera 24R - 2014
Life is Good - All is Well
richhop25 is offline   Reply With Quote
Old 09-25-2015, 07:41 AM   #5
CCRVOC
Ramblin Recks's Avatar
There are some other pictures showing what you describe but I could not find them.
RV Solar Panels Roof Installation Overview and Video
2012 Dodge 3500, SLT Big Horn,CC,DRW,Cummins HO, EB, 4x4, 3:73, Retrax Pro, Q20, TST507, Garmin RV760, Sleek 4g
2014 Cedar Creek, 36CKTS, 640w Solar, TriStar MPPT 60, Magnum 2000w, PI EMS, WiFi Ranger Elite, Sleek 4g, Wingard DTV Traveler
Retired Army in 1995, and now retired in 2016
Ramblin Recks is offline   Reply With Quote
Old 09-25-2015, 02:33 PM   #6
I like the look of these mounts but actually think you might do more damage to the roof when you took them off than if you used a drilled mount. I've always used a home made mount out of angle aluminum. Two pieces connected via stainless steel bolt and then screwed into the roof. One puts a dab of ProFlex under the foot before screwing it down and then puts a dab on each of the screw heads. If I were to take the panels off, I would disconnect them from the foot and leave the foot in place for the next guy! Or sell the solar system to the next guy and don't worry about it.
There are already a lot of penetrations in your rubber roof. You adding a few more, especially if you are careful and seal correctly is not going to cause problems.
Kelly
Show Low and Rio Verde, AZ
cuernoverdesolar.wordpress.com
Klipstr is offline   Reply With Quote
mount, roo, roof, solar, solar panel
