Old 05-20-2016, 12:27 PM   #11
Yes, I agree ... I've had my eye on the Victron BMV-702 for a while now since it has temp monitoring also.
The reason for the 75A is:
1 - It doesn't hurt anything
2 - It was "only" $40 more
3 - I may need to go with more batteries so it would be needed for faster charging
4 - Randy at Best Converter recommended it after hearing what I plan on doing.
thanks
John M
2013 GMC Sierra 2500DH CC, 4x4, D/A
2016 Forest River Vengeance 25V TT/TH
johnm1 is offline   Reply With Quote
Old 05-20-2016, 06:55 PM   #12
CaptnJohn's Avatar
Originally Posted by bob dirt View Post
I almost always dry camp. My portable solar panel has been my best investment so far. If it's not raining, there is always some sunlight close enough to move it to. I have only used the genny for the microwave and that's not very often either
Which portable panel did you use?
2017 Montana HC 370BR
2016 F350 diesel
Edgewater 205 EX 150 Yamaha
Old 05-20-2016, 10:53 PM   #13
nodrawers's Avatar
Portable + Roof
I installed a trimetric monitor and controller for 200w portable & it works so well I added 200w to roof since I had most of the expense in the controller & monitor. The portable just plugs in parallel with roof when needed for 400w. Just got back from 3 weeks all solar and no problems. I only have one 114AH batt & think I should replace with 2 6v GC batt as original post did. I think that would be my best upgrade.
Tom & Laura USAF Ret Smsgt
1995 2500 5.9 Cummins 5 sp 3.54 diff
2011 Coachman Catalina 22FB
Days Camped 2016 91, 2017 110
nodrawers is offline   Reply With Quote
Old 05-20-2016, 11:14 PM   #14
bob dirt's Avatar
I bought the zamp ZS-120-P folding 120w for it's convenience. It was a little pricey but it's easy to stow and has a weatherproof controller and a carrying case. It works good for what I need
2016 Forester 2401WS MBS
Life is short...eat the cookie
bob dirt is offline   Reply With Quote
Old 05-20-2016, 11:47 PM   #15
CaptnJohn's Avatar
I keep the 5er in storage when not in use. It gets little use during summer months. I'd simply like to keep the battery maintained ~~ or I'm going to add a 50 amp receptacle in the yard to charge things and get the refer cold before we leave on trips.
2016 F350 diesel
Old 05-22-2016, 07:47 AM   #16
I kind of wonder if the biggest "bang for my buck" was to replace the battery connectors. Like I said in the OP, I pulled 3 of the 4 off with pliers without much of an effort (2 at the battery & 2 at the battery disconnect switch). If I were to have large current draws with an inverter, I'm guessing it would have caused some problems. Maybe even with trying to recharge with the generator?
John M
Old 05-22-2016, 07:48 AM   #17
Kenny kustom's Avatar
No need for the expense of the 50a.
A 30a will do just fine. Unless you want both ac.
2016 Sabre 36QBOK
2015 Ram 3500 CUMMINS
2017 Dynamax Isata 4
Old 05-22-2016, 08:04 AM   #18
Originally Posted by johnm1 View Post
The charger is a direct replacement for the WFCO unit so it's in the same spot as original which is roughly 12ft from the batt's. The rig came with 6 awg wire and that should serve me well ... for the time being ... I hope.
Per a voltage drop calculator using 6 awg wire, 40 amp load (though your charger is 75 amps), 12 foot run:
Voltage drop: 0.38 volts
Voltage drop percentage: 3.17%
Voltage at the end: 11.62
Going from 12 volt to 11.62 doesn't sound like much, but I feel the drop will greatly increase your charge times in bulk charge mode of 14.5 to almost 14.1 volts.
My camper's converter was 25 feet rear of the batteries up front. That distance and thin wire caused a .5 volt drop which I didn't realize or consider due to lack of knowledge on the subject. I couldn't figure out why it was taking me 8 hours of running the generator to charge my battery banks each day after running heater all night. I had upgraded my converter to a 70 amp PD 3 rate charger and was upset that it wasn't charging much faster than the stock 40 amp charger. Moving the converter within 3 feet of the batteries fixed the issue. Morning charge is about 2.5 hours on generator but since then I've gotten solar and the generator is collecting dust.
Skyliner is offline   Reply With Quote
Old 05-22-2016, 08:17 AM   #19
[/B][/COLOR]
Tony is right. On my RV the charger is 22 feet from the battery bank and wired with a round trip of #6. On my 70 amp converter this costs me about .5 volts which drops me to 14.1 or so in boost mode (I force it using the pendant). This is a problem. My current plan is to ground the converter to the chassis and eliminate at least the 22 foot negative run, which cuts my voltage drop in half. Don't know why FR didn't do that.
2015 335DS
ScottBrownstein is offline   Reply With Quote
Old 05-22-2016, 08:26 AM   #20
I'm learning here ... where does the 40A load come from?
John M
battery, charging, upgrade
