Old 05-20-2016, 08:07 AM   #1
My battery & charging upgrades
We've always had problems lasting more than a few days and then charging the normal dealer installed Interstate Dual Purpose group 24 battery with the generator became a 2x/day chore until we went home. At home, it's plugged in 24/7 so it's always fully charged when we leave for the next trip.
I've been on a mission to upgrade my electrical system to extend our dry camping time. We camp in the woods a lot so solar wouldn't be the "best" option for us and we have a pair of Champion 2K invertor genny's with parallel kit to use as needed.
With this knowledge, I've changed over to a pair of 6v GC batt's (230AH total), so I've almost tripled my battery capacity. I've replaced the factory generic 55A WFCO charger with a 75A Powermax Boondocker (PM4B-75 MBA) and, almost as important, I replaced all of the crappy crimped on ring connectors that the factory put on with proper tinned battery lugs because 3 of the 4 that I've replaced so far I've been able to pull off the end of the wire with my pliers ... meaning they had a very poor connection for charging!
BTW: all lights are LED, we have no inverter (so no 120VAC things) and we try to be very conscious of the power we use.
What do y'all think?
John M
2013 GMC Sierra 2500DH CC, 4x4, D/A
2016 Forest River Vengeance 25V TT/TH
johnm1 is offline   Reply With Quote
Old 05-20-2016, 09:30 AM   #2
Your upgrades will work out just fine, that will be a huge improvement for boon docking.
Congrats and Happy Camp'n !
2007 Surveyor SV230
- 200 Watts Solar/MPPT Controller - 230 AH Battery Bank - 600 watt PSW Inverter - (2) 2000 watt Inverter Generators - LED Lighting
Boon Docking 99% of the time.
2009 F150 - 5.4 Litre - Tow Package
boondocking is offline   Reply With Quote
Old 05-20-2016, 09:38 AM   #3
Where in relation to your batteries is your new converter installed?
Skyliner is offline   Reply With Quote
Old 05-20-2016, 09:41 AM   #4
I have done the very same things. One other item that you may consider, check your Fridge to make sure you don't the version with an always on heater. It was recommended to me to do an easy mod to allow that to be disconnected and save power
2015 Ram 2500 4x4 6.4l with 2015 Sandpiper 25RLS
Wife, myself and 2 furry kids
Mountndream is offline   Reply With Quote
Old 05-20-2016, 09:41 AM   #5
The charger is a direct replacement for the WFCO unit so it's in the same spot as original which is roughly 12ft from the batt's. The rig came with 6 awg wire and that should serve me well ... for the time being ... I hope.
John M
Old 05-20-2016, 09:44 AM   #6
It's the 1st Norcold fridge I've had so I'm not 100% sure if it does or doesn't have the heater. But, I don't think it does because I haven't found a switch ... yet.
On edit: anyone know if the Norcold has a perm type heater???
John M
Old 05-20-2016, 09:49 AM   #7
I believe its the Dometic fridges that have the heaters. (at least mine was)
The issue is that they didn't put a switch on it, hence the Mod
Old 05-20-2016, 10:10 AM   #8
bob dirt's Avatar
I almost always dry camp. My portable solar panel has been my best investment so far. If it's not raining, there is always some sunlight close enough to move it to. I have only used the genny for the microwave and that's not very often either
2016 Forester 2401WS MBS
Life is short...eat the cookie
bob dirt is offline   Reply With Quote
Old 05-20-2016, 11:45 AM   #9
camaraderie's Avatar
@John... I think you've made very good choices though 75 amps is overkill for your present setup which can accept a max of around 45 amps in bulk charge mode...but it will be good insurance if you find you need another bank to meet your needs.
The next upgrade should be a TRUE battery monitor like from Trimetric or Victron that will let you know where you stand on the battery charge and charging process AND help you understand your usage & loads. It will also pay for itself in extending your battery life & cycles. No rush...but anyone who boondocks a lot need one! About $150 for the excellent Victron. A bit more for the also excellent Trimetric.
https://www.victronenergy.com/upload...-series-EN.pdf
________
Cam
2015 Georgetown 280DS
2014 Vespa LX150 2014 StellaAuto 125
camaraderie is offline   Reply With Quote
Old 05-20-2016, 11:54 AM   #10
X2 on what Camaradierie said. You will be amazed at the information you can view and learn from with a monitor. We have been very pleased with our Trimetric.
2013 Flagstaff 8528IKWS, 2006 F-350 6.0L
DickiedooFlagman is offline   Reply With Quote
battery, charging, upgrade
