Old 01-30-2014, 07:41 AM   #11
Herk7769's Avatar
I contacted my local agent at Deka Batteries for information when I was programming my battery monitor:
The agent for Bucks county is :
DAVE ECKHART
Phone : 610-944-3140 ext. 3800
Email : deckhart@dekabatteries.com
EAST PENN MANUFACTURING COMPANY INC
DEKA ROAD
LYON STATION, PA 19536
I also have a pair of Deka DP-24's
He said my battery is 75 AH and that seems to work OK as a setting in the computer; but is in reality "high" for this Dual Purpose Marine battery. I have been waiting for them to die - or even get sick - (5 years on the pair now) but they seem to want to live forever.
To convert RC (Minutes of Reserve Capacity at 25 AMPS - the "Industry Standard") to AH (Amp Hours - hours capacity at 20 amp draw) the minutes available at 25 amps is multiplied by 0.4167.
Trying to use the 110 minutes at 23 amps (stamped on the battery) is tricky due to the Peukert Effect which makes AH capacity non-linear based on actual demand. (See chart and document on the effect.)
Using Awwall's 120 minutes at 25 amp RC; the calculation results in a 50 AH capacity as he states and seems much more correct than the 75 AH quoted by the Deka Rep back in 2009 when the batteries were new.
My performance is most likely even worse when you conciser the charge/discharge cycles my battery has undergone in 5 years.
See capacity reduction vs charge cycles graph as well.
Name:	battery voltage and capacity Curve vs Discharge Rate.jpg
ID:	45513   Click image for larger version
Name:	battery Life as a function of charge discharge cycles.jpg
HAM CALLSIGN - KC3FFW
Old 01-30-2014, 07:43 AM   #12
Herk7769's Avatar
For some reason my JPG is not showing on my PC so here goes again.
ID:	45518   Click image for larger version
Old 02-03-2014, 02:15 PM   #13
Fulltime family RVer
Given this charger/maintainer - it has switched over to "maintain" mode. Is it safe to leave hooked up for another couple of weeks until we get the camper back?
Old 02-03-2014, 02:19 PM   #14
Herk7769's Avatar
I don't see why not...
Old 02-03-2014, 02:34 PM   #15
fonzie's Avatar
I would say yes, fully automatic. Also did you find built date underneath battery?
Fonzie
Old 02-03-2014, 02:54 PM   #16
Completely forgot about it. I'll check shortly...
Old 02-03-2014, 03:04 PM   #17
Brother Les's Avatar
With a battery that you can take the caps off. check each cell to see if you have any weak ones after you have charged it up.
https://images.search.yahoo.com/sear...rometer+tester
Brother Les
Old 02-03-2014, 03:09 PM   #18
Triguy's Avatar
Doug - Looks like that charger will maintain with a very low current for an extended period so you should be fine to leave it connected.
But, you could also just leave your batteries in storage unconnected. A healthy battery will take months to self-discharge in storage where they are not hooked up to anything.
Plus, you can test them in a couple of weeks to see if they are still holding the charge. Make sure to add distilled water if needed before you store.
Scott
DW, 3 Kids and our Goldens
2012 Shamrock 233S
2008 Toyota Sequoia 5.7L 4WD
Old 02-03-2014, 03:25 PM   #19
Understood and that's actually how I have handled the last two seasons. Whenever I would store the camper for more than a couple of days, I would disconnect the battery using the battery disconnect my father-in-law and I installed (when you read that, understand that he did 90% of the work and I held the flashlight).
I may get a hydrometer to test the battery itself. Thanks for the idea, if nothing else.
Old 02-11-2014, 07:28 AM   #20
dcheatwood's Avatar
Here you go.
Harbor Freight
I caught these on sale for $2.99 a couple years ago. Keep one on my mower all winter and on the ATV if not using it for a while.
2013 Rockwood 8282WS
Reese Revolution Pin, Reese 16K
2008 Tundra Limited Double Cab 5.7L
Air Lift 5000 w/Wireless Air
battery, water
