Old 02-12-2014, 06:47 AM   #21
Herk7769's Avatar
I have Battery Tender Juniors on my 3 sump pump backup deep cycle batteries. They are on 24/7/365 with no problems.
http://www.walmart.com/ip/15779492?w...264470&veh=sem
They are 4 stage chargers (including a desulphate stage).
HAM CALLSIGN - KC3FFW
Old 02-12-2014, 07:24 AM   #22
RKR
RKR's Avatar
My battery, water level and charger - it's surprising what I don't know
Great thread. Lots of good info. I have the battery tender Jr like Herk has. I followed hid advice from a previous thread.
My battery has been on it since Nov except for a couple times when I took the battery to go check trailer. It's been working fine.
RKR is offline   Reply With Quote
Old 02-12-2014, 07:49 AM   #23
Triguy's Avatar
Those Battery Tender Jrs are a great bang for the buck. I have used one for my motorcycle battery since I bought the bike. The first battery lasted 10 or 12 years as I recall. I credit that charger.
Scott
DW, 3 Kids and our Goldens
2012 Shamrock 233S
2008 Toyota Sequoia 5.7L 4WD
Old 02-16-2014, 12:14 PM   #24
Boots49's Avatar
Send a message via Skype™ to Boots49
Let me see if I am correct, since I can not plug the battery in at storage, I bring it home & charge it once a month, checking the water level, it is in the house from November until April. You are saying, check the water monthly & plug it into a Battery Tender Juniors, for the whole time. At the camp ground it is plugged into the 120 volts from May until October, I also check the water once a month. Is this correct?
Al & Susanne
Aka: Puss 'n Boots
Wildcat 31 TS - Silverado 2500 DuraMax Diesel
Tip of the Day: Stay safe, have fun and never leave the cat out in the rain!
Boots49 is offline   Reply With Quote
Old 02-16-2014, 12:18 PM   #25
Fulltime family RVer
I was put in the garage yesterday to get my heat gun for the limoncello shrinkwrap tops and saw that my battery was wet on top and on the workbench:
Name:	ImageUploadedByForest River Forums1392574662.160861.jpg
The water level didn't appear to change much when I popped the caps and looked.
Any idea why this may have happened? Crappy charger, perhaps?
Old 02-16-2014, 03:41 PM   #26
fonzie's Avatar
Usually this happens when to much water is added and then a normal charge is done, otherwise I think it would be an overcharged by the charger which would be causing heating/boiling of the electrolyte or you have a bad cell causing excess heat in that cell......
Fonzie
Old 02-17-2014, 06:47 PM   #27
RPAspey's Avatar
Attachment 46336
Looks like over charging to me.
2000 Cherokee 31BH, "flipped axles and raised",LEDs, solar, inverter, etc..aka "boondock ready". '07 Tundra 5.7L DC-LB, modded as well.
2000 Cherokee 29BH with 6V batteries, LED lights & 400 watts of solar power, flipped axles and raised. 2007 Tundra 5.7L DC-LB with lots of mods. C-co, 8/158th AVN Maint.
RPAspey is offline   Reply With Quote
Old 02-17-2014, 09:22 PM   #28
Triguy's Avatar
Have you had a chance to test this battery yourself or at the local battery store? Just curious what the results of a load test would be.
As for the water on top, I think I'd agree about the overcharging, but you could have also added too much water.
There could be one other thing when you added water. Do you recall if you add the distilled water before or after you began the charge cycle? I have seen wet tops like this when the water was added before charging, which is the incorrect way. Always charge first and then add water (caveat - it's ok to add just enough to cover the plates before charging but that is the exception).
Lastly, Doug, did you check for any cracks in the casing?
Scott
2012 Shamrock 233S
Old 02-17-2014, 09:55 PM   #29
Denver, CO
garbonz's Avatar
That battery is fine for your use, and may last for awhile yet. I personally do not favor keeping a battery plugged into a charger if it can be disconnected for storage. But I am in the minority, it seems.
Group 24 battery's are typically in the 75-80 amphour range but if your use is plugged in then it don't matter much.
I did spend a bit of $$$ on a 7 amp CTEK charger that has 8 stages and am checking that out, but the more basic charger probably do 95% of what's needed, especially if they are not left hooked up.
2017 Fuse 23T
Old 02-17-2014, 10:22 PM   #30
I've never added water to this battery nor have I had it tested. I think we have a BatteryPlus in town- I'll try taking it to them one day this week and see what they say about it. I should also order a hydromagic tester so that I can verify it myself (I'm not the trusting sort).
I haven't removed the battery from the camper before nor had I ever checked the water levels. I installed a battery disconnect and simply disconnected the battery when not in use. I left my stock converter handle the charging. This all was something new for me- solely because the battery was so dead when the driver went to pickup the camper this past time.
battery, water
