Old 01-29-2014, 05:44 PM   #1
Fulltime family RVer
My battery, water level and charger - it's surprising what I don't know
Ok, since my battery was so dead last week that it wouldn't run my landing gear, I brought it home to charge it up.
Here is my Walmart special battery charger:
Name:	ImageUploadedByForest River Forums1391038609.245674.jpg
ID:	45494Click image for larger version
Name:	ImageUploadedByForest River Forums1391038638.062749.jpg
I bought this back when I had my pop-up. I didn't know what I was doing then an still don't! I normally don't pull my battery out and generally let my converter charge it and disconnect to keep it from being depleted.
I first checked my water levels (YouTube educated!). I think they're ok:
Name:	ImageUploadedByForest River Forums1391038705.114885.jpg
ID:	45496Click image for larger version
Name:	ImageUploadedByForest River Forums1391038731.749279.jpg
I think they look OK and not frozen (my book told me not to charge a frozen battery, so I was checking).
Finally, here's my battery. Can anyone tell me anything about it? It doesn't seem to have amp-hours listed. Being a starting + deep cycle battery, it doesn't seem best suited for an RV, but we so rarely use battery power only, I think it's OK for now.
Name:	ImageUploadedByForest River Forums1391038945.433728.jpg
ID:	45498Click image for larger version
Name:	ImageUploadedByForest River Forums1391038962.278395.jpg
ependydad is online now   Reply With Quote
Old 01-29-2014, 06:43 PM   #2
fonzie's Avatar
Here is some info on Deka Marine Master.
http://www.dekabatteries.com/assets/base/0181.pdf
Also I find this to be a good site for battery info
http://www.batterystuff.com/kb/artic...-basics.html#4
Fonzie
Old 01-29-2014, 06:56 PM   #3
Oakman's Avatar
If the battery is 5 years old or older I'd replace it with a true deep cycle battery.
Bob and Joyce
2013 CC Silverback 29RL
2010 Ford F250 XL Crew Cab 6.4 liter diesel
ATU Local 788
Oakman is offline   Reply With Quote
Old 01-29-2014, 07:18 PM   #4
It's the battery from the dealer. Should be about 2 years old. But it sure isn't well marked on the battery:
Name:	ImageUploadedByForest River Forums1391044708.268203.jpg
Old 01-29-2014, 07:28 PM   #5
fonzie's Avatar
If you are looking for a built date, then look underneath the battery for two stamped year and month...the top one is usually for when it was put in service by the dealership.
Fonzie
Old 01-29-2014, 08:06 PM   #6
That makes sense. I can't imagine my dealer taking the time to mark the top. I'll look after it charges for a while.
Old 01-29-2014, 08:07 PM   #7
I know scale is hard to see- but does the water level look right?
Old 01-29-2014, 08:30 PM   #8
fonzie's Avatar
Yes water level is OK. It should cover plates by at least 1/4 inch electrolyte.
Fonzie
Old 01-29-2014, 08:33 PM   #9
Triguy's Avatar
Kind of hard to see, but looks good with the water covering the plates. Ideally, the water level should be no higher than just below or to the bottom of the tubes, but the main thing is to always have the plates covered.
Remember, though, only use distilled water.
Scott
DW, 3 Kids and our Goldens
2012 Shamrock 233S
2008 Toyota Sequoia 5.7L 4WD
Old 01-29-2014, 09:21 PM   #10
Phat Phrog Stunt Crew
awwall's Avatar
Here is your batter specs:
Battery Specifications:
Cold Cranking Amps at 0F : 550amps
Marine Cranking Amps at 32F : 685amps
Minutes at 25 Amp: 120min.
10-3/4" L x 6-3/4" W x 9-3/8" H
This battery should provide you with a 2.5 amp draw for 20 hours or 25 amps for 2 hours. This should be a 50 Amp/hr battery.
I think I am correct.
NOT TO GOOD!
Wayne & Susan Biloxi,Ms
2012 GeorgeTown 351DS...2015 Ford Focus/Brake Buddy
FROG Member
awwall is offline   Reply With Quote
battery, water
