Old 09-12-2016, 10:56 AM   #1
Back On The Go
My generator stops running when going over bumps, rough roads
My 5.5 Onan genset cuts off on its own if I am driving on a rough road (hard to go around these), go over a rough railroad crossing, hit a pot hole, etc. On a previous trip, one of the two 30 amp breakers would trip, but on this last trip, both breakers are still on after the generator stops. I am running 1 A/C, and, per FR advice due to known problems, have the vent on the A/C open, as opposed to closed which would direct the cool air into the overhead ducts. I also experience what sounds like the A/C almost shutting off, but staying on, and then quickly getting back to full capacity as I am driving along. Any help on this issue so I can stay cool while driving? (sorry, I put this post into the general discussion first by accident).
Thanks.
2016 Georgetown 270S
2013 Ford C-Max Hybrid
2 Janis Hybrid Bicycles
Not too serious about anything except what affects health and happiness.
salwolfe is offline   Reply With Quote
Old 09-12-2016, 10:59 AM   #2
Make sure your oil is right up to the full mark. There is a low oil sensor that might be cutting it off.
2015 335DS
ScottBrownstein is online now   Reply With Quote
Old 09-12-2016, 11:11 AM   #3
Back On The Go
Thanks. I check it regularly and it is maybe 1/4" below total full mark, but I'll put more in.
Old 09-12-2016, 11:25 AM   #4
TheLarks's Avatar
Thanks.
We have had the same problem with our new MH. Thanks in advance for all the helpful advice. Deb
Mitch & Debbie
Maggie, the Wonder Dog
2015 GeorgetownXL 352
2016 Jeep Wrangler Unlimited
TheLarks is offline   Reply With Quote
Old 09-12-2016, 01:40 PM   #5
I have a Generac that shuts off going down the road also. It starts right up again but will shut down again for no apparent reason. Oil is full and breakers are not tripped. Runs fine when the unit is parked. Any ideas?
wildcatmlm is offline   Reply With Quote
Old 09-12-2016, 01:47 PM   #6
Many generators use a spring loaded, coil activated contactor in the transfer switch to transfer the electrical power to the coach once started.
I've seen some of these that 'bumps/rough roads' would jar the contactor enough to disconnect.
Just a possibility.
2016 Flagstaff 8529IKBS Diamond Package 5th Wheel
Ford F-Series SCREW 4x4
TST Tire Monitor - Sinemate 3500w Gen.
2016 Nights Camped = 46
Old 09-12-2016, 02:00 PM   #7
It's worth a shot.
Old 09-12-2016, 02:07 PM   #8
Also, on the onan units they need a valve adjustment after the first 50 hours or so. The valves tighten up during breakin. That will cause a severe loss of compression.
Havasudave is offline   Reply With Quote
Old 09-12-2016, 02:33 PM   #9
ilmor's Avatar
Maybe they are getting fuel starved - their fuel pickups are supposed to be at the 1/4 tank level, but maybe they aren't or the fuel was too low?
2017 Forest River Sunseeker 2250SLE
ilmor is offline   Reply With Quote
Old 09-12-2016, 04:12 PM   #10
As for mine, the fuel has been at least 1/2 tank if not more. Thought it might be a fuel filter problem but it only quits going down the road.
generator
