Old 05-14-2012, 07:56 AM   #11
Bennington Camper's Avatar
What did you use as the 'feet' for the module mounts?
Off the shelf stuff or did you fab your own from angle stock?
Glenn - KA2DTH
2007 Chevy Express 1500 AWD
2005 Surveyor SV-230
Bennington Camper is offline   Reply With Quote
Old 05-14-2012, 07:59 AM   #12
Also - how did you mount the module feet to the roof of the trailer?
I saw some Simson galvanized brackets at a local big box store that look like they might do the trick, and I have aluminum L feet used in residential PV installations, but they look like overkill.
Glenn - KA2DTH
Old 05-14-2012, 11:11 AM   #13
ronhanson's Avatar
AM solar makes some nice but spendy mounts that work with some tilt bars they also sell. AMsolar
Ron Hanson
2009 Georgetown 350TS (bunks)
400W solar, 440AH 6V GC2
2009 Ford Edge AWD Ltd towed
2011 Honda Fit Sport towed
ronhanson is offline   Reply With Quote
Old 05-14-2012, 06:53 PM   #14
RPAspey's Avatar
mounting the panels..
the panel feet use aluminum angle. between the aluminum angle and the roof is a piece of 1/4" rubber. its all bolted to the roof using these "new fangled" toggle bolts. I couldn't believe how much they held in 1/4" particle board.
I had a hard time convincing myself to punch a 1/2" hole into the roof for each bolt, 2 each bracked for a total of 24 holes. I used Dicor between the roof and rubber, between the rubber and bracket then coated the whole thing with DiCor.
when it quits raining I'll go up top and take pix of feet from a different angle.
Name:	anchor test 1.jpg
ID:	13785   Click image for larger version
Name:	anchor test 2.jpg
2000 Cherokee 29BH with 6V batteries, LED lights & 400 watts of solar power, flipped axles and raised. 2007 Tundra 5.7L DC-LB with lots of mods. C-co, 8/158th AVN Maint.
RPAspey is offline   Reply With Quote
Old 05-17-2012, 07:49 AM   #15
RPAspey's Avatar
here's another view of the roof anchor. I'm trying the App for my phone so lets see if I got it right.
what???? it posted the pix upside down. sorry about that.
Old 07-04-2012, 11:14 PM   #16
Southwestern Newbie
Misterdanderson's Avatar
Thank you so much for sharing. We just got our first travel trailer (not counting the popup we used for three years) and haven't even taken it out yet. I'm going to install a solar kit and you have inspired me to add a tilt instead of just mounting them flat. Great pics and ingenuity. I can't wait to seeif my wall is also not stapled under the trim.
Misterdanderson is offline   Reply With Quote
electrical, modifications, solar, solar panel
