Old 06-30-2014, 07:06 PM   #1
cjardine78's Avatar
Mystery Switch
Anybody know what this little knob is for??it clicks in & out & has 2 wires going to it..can't hear anything start or stop when I play with it.im new to this trailer stuff..thanksClick image for larger version
Name:	ImageUploadedByForest River Forums1404173137.212394.jpg
ID:	56823Click image for larger version
Name:	ImageUploadedByForest River Forums1404173156.743315.jpg
ID:	56824Click image for larger version
Name:	ImageUploadedByForest River Forums1404173174.357754.jpg
cjardine78 is offline   Reply With Quote
Old 06-30-2014, 07:13 PM   #2
GlacierGus's Avatar
It could be your battery "cut off" switch. This turns off all the little lights, sensors etc. when you don't want any drain on the battery, when in storage for example. I have a different TT but that is what my switch looks like.
2013 Rockwood Mini Lite 2109S
2006 Dodge Durango Hemi 5.7
Equal-i-zer WDH
GlacierGus is offline   Reply With Quote
Old 06-30-2014, 07:32 PM   #3
cjardine78's Avatar
A Few Pictures - sport
Well everything still works when I push it in so I will keep investigating..previous owner said they never touched it cuz they didn't know what it was..FYI it's a 1999 22" wildwood toy hauler .thanks
Old 06-30-2014, 07:39 PM   #4
NELA
Weezer's Avatar
(chuckle) There's a lot of discussion about which way is which on a battery disconnect, so DH and I tested ours and made a label for it;
Out is On
If age is a state of mind, and I've lost my mind, I'm AGELESS, right?
Give me 40 acres and I'll turn this rig around:
Flagstaff 5er 2014 8528 IKWS, Platinum Package, Regency Interior "Buffy"
F250 Super Duty 2013 Tuxedo Black "Biff"
Days camped 2014: 30
Weezer is offline   Reply With Quote
Old 06-30-2014, 07:40 PM   #5
Orion's Avatar
Battery switch, but looks like it was installed for something else. Probably just have to trace wires...
2017 Flagstaff FLT21DS
2011 Tundra Platinum, 5.7l, 2WD, Firestone bags...
Orion is offline   Reply With Quote
Old 06-30-2014, 07:56 PM   #6
cjardine78's Avatar
I chased them.1 goes to a little junction bolt & the other to a positive on 1 of the batteries..everything works weather it's in or out..thanks for all the input..Click image for larger version
Name:	ImageUploadedByForest River Forums1404176165.576393.jpg
ID:	56835Click image for larger version
Name:	ImageUploadedByForest River Forums1404176178.619042.jpg
Old 07-01-2014, 09:21 AM   #7
Always Learning
Are you running off of battery when everything still works? Or are you plugged into shore power? If your camper is still plugged in, your converter usually works without a battery and it could look like this battery disconnect doesn't do anything.
Old 07-03-2014, 11:12 AM   #8
cjardine78's Avatar
I'm on battery power.i checked with a volt meter @ the knob & it had juice..I will keep playing around with it.thanks for all the help
Old 07-03-2014, 11:44 AM   #9
Ford Idaho's Avatar
Does your TH have a fuel tank and pump for the toys?
Old 07-03-2014, 12:25 PM   #10
cjardine78's Avatar
Nope.h20 pump still works either way as well
Old 07-03-2014, 12:30 PM   #11
Ford Idaho's Avatar
Dang.
How about tank heaters, factory or aftermarket?
Old 07-04-2014, 05:09 AM   #12
I believe it is the battery knob but if hooked up to truck it is overridden. Unplug from truck and it should work to kill the battery when pulled.
John
laurajean is offline   Reply With Quote
