Old 07-13-2016, 02:40 PM   #1
Need 6V battery Dimensions
Hi,
I have a Forester 2251 SLE with dead or dying house batteries. The coach is up in the mountains and I'm home. I want to replace the 2 12V with 2 6V batteries. I measured the compartment size before I left and my notes say the compartment is 10.5 inches deep. The shortest 6V battery I can find is Duracell Group GC2 which specifies the height as 10.875 inches. Anybody have more exact dimensions for the compartment? If not I will have to go with the 12V in parallel.
Thanks,
Bob Schoner
rschoner is offline   Reply With Quote
Old 07-14-2016, 05:01 PM   #2
Update
Hi,
I went to the dealer and measured the compartment of a similar model. It measures 11 inches from the bottom to the top of the rubber gasket the step rests on when closed. I measured the 6 volt battery in the store and it is very close to the 11 inch height. So, I am abandoning the 6 volt changeover for now and replacing with 2 12 volt batteries. Maybe when I am home I can see if the compartment can be made a little deeper. I am not comfortable with 0.1 inch clearance since the rubber can compress and the step might deform under load.
Bob Schoner
Old 09-26-2016, 03:43 PM   #3
what type batts did you use? I was hoping the 6v to be ok. maybe I could shim 1/8". want max batt when no gen time.
larry.mahoney is offline   Reply With Quote
Old 09-30-2016, 09:13 AM   #4
Too Tall's Avatar
Two 6 volt batteries from Battery Plus Duracell but made by Deka for $100 each will give you a total of 230 amp hours. That's hard to beat Syria
Rockwood 2104S, 2014 Ram 2500 Diesel.
USMC 68 -70
Too Tall is offline   Reply With Quote
Old 09-30-2016, 09:28 PM   #5
Costco and Sams Club sell the Interstate 6V golf cart batteries. Mine were $150 for the pair (232AH) from Costco, including tax after core turn-in. Considerably cheaper and more power than dual 12V. I believe my Interstates are 10.75 inches tall, just under 11 inches long, and 7.25 inches wide. They fit snugly into a dual size 24 box, but they fit better than the 24s did. The 12V size 24 batteries actually overlapped the end ridges slightly.
I went to Costco and measured the batteries after accurately measuring the box before I bought any batteries.
Fred W
Old 10-01-2016, 12:26 AM   #6
6v replacement
I have 2016 Chevy 2251 slec Forester with these batteries fit? Wish there was an area for more batteries. I can't find good info on batteries size vs how much I can draw & recharge. I see all kinds of numbers 80% or 50% draw down then how much time and amps to recharge? I like to boondock.
battery
