Old 04-20-2014, 06:27 PM   #11
BombDoc's Avatar
Originally Posted by shadow7663 View Post
Do you have anything else running on the same circuit as the GFI? If so when you plug in the shore power to the camper it could be overloading the circuit and causing it to trip.
See if you can plug into another outlet on a different circuit. I've had this happen to me before.
Not sure if anything else is on those breakers. I've had the RV plugged into one of them for a year. I will see if I can plug into something else.
John & April & "Scout"
2013 Sabre 32RCTS-6
Nights Camped 2013-(44) 2014-(59) 2015-(47)
2016-(32) 2017-(13) 2018-0
BombDoc is online now   Reply With Quote
Old 04-20-2014, 06:28 PM   #12
BombDoc's Avatar
Originally Posted by Rrickim63 View Post
Try another outlet that is not gfci in house. 2 gfci outlets tend to fight each other.
1999 Silverado with tow package
2006 Roo 23B hybrid
I'll try that too. Thanks.
2013 Sabre 32RCTS-6
Old 04-20-2014, 06:29 PM   #13
BombDoc's Avatar
Originally Posted by markb5900 View Post
What I would do then is turn off all the breakers in the trailer.
Plug it in again, and see what happens.
If it doesn't trip, turn one breaker at a time and and see which one causes the GFCI to trip. Should narrow down your problem then.
That is my next step. will post an update when I try this.
2013 Sabre 32RCTS-6
Old 04-20-2014, 06:42 PM   #14
Run the slides back out and try it again.
Old 04-20-2014, 07:23 PM   #15
Phat Phrog Stunt Crew
elind's Avatar
Having too many amps trips the circuit breaker. But GFCI trips when the hot line finds a ground in a appliance. Even an 1/2 amp appliance can be a problem. Start by unplugging everything on the GFCI line and turn them on one by one. This may pin point the problem.
2014 Wildcat 327ck
elind is offline   Reply With Quote
Old 04-20-2014, 08:12 PM   #16
BombDoc's Avatar
Thanks all for the suggestions. I'm going to have a go at it tomorrow. Out of day light and just sat down for the evening. Thanks again.
2013 Sabre 32RCTS-6
Old 04-21-2014, 03:17 PM   #17
You are going to find out that GFI circuits in an RV circuit can be real problem. Here are a few GFI things that might help. Possibly the pump in your dehumidifier is the problem.
GFCI breakers are designed to cut the power in the blink of an eye if electrical fluctuations of as little as .005 amperes are detected. Because the GFCI is so sensitive, it is most effective when wired to protect a single location. The more outlets any one GFCI protects, the more susceptible it is to phantom tripping shutting off power because of tiny, but normal fluctuations in current flow.
GFCI breakers can also be tripped by occurrences such as electrical storms and by moisture from rainfall. It is important that the outlets for the GFCI be kept dry and protected from the elements. Some GFCIs are more sensitive that others.
It may be that the GFCI is too sensitive. It is normal for continuous running motors, such as pumps, to sometimes have small electrical fluctuations. Sensitive GFCIs may detect this and falsely trip. You may want to have the electrician try a new GFCI or a different brand of GFCI if this problem persists.
cadman99 is offline   Reply With Quote
Old 04-23-2014, 06:35 PM   #18
BombDoc's Avatar
Thank you Cadman!
2013 Sabre 32RCTS-6
Old 04-23-2014, 06:39 PM   #19
BombDoc's Avatar
Here is the latest. Turned off all the breakers in the RV, reset GFCI, plugged in the extension cord to the RV, immediately tripped. Did OC's suggestion, ran the slides back out using battery power. Reset all the breakers in the RV to the on position. Plugged in extension cord and no trip of GFCI. Microwave shows power. Plugged in dehumidifier, and turned it on, no trip. Right now everything is working as normal. Could this be the phantom tripping cadman discussed or could the slides being pulled in be shorting something out? Hate to leave it open all the time due to billions of oak leaves. Prefer to keep it closed with dehumidifier running (we already need it down here) and battery charging and have the ability to turn fridge on at a moments notice.
2013 Sabre 32RCTS-6
Old 04-23-2014, 06:41 PM   #20
markb5900's Avatar
It sounds like your slides are pinching a wire when being in, causing a dead short.
I would get down on the hands and knees and take a look at the wires as the DW brings the slides in.
Mark B
2015 32 Foot Rockwood 8289WS 5th Wheel
2017 GMC 3/4 Ton TV
markb5900 is offline   Reply With Quote
