Old 04-13-2013, 05:52 PM   #11
Originally Posted by Stanleyg View Post
How do you have the charger set up on them? You should have it set up so the positive is off the first battery and the beget ice should be off the last battery. This charges and draws voltage off all the batteries at the same amount.
I will try swaping the positions as you suggest BigTJohn.....
Meanwhile here's a diagram of how it's wired. The Green lines are the leads going off into the coach. Why there are two positives and two negatives I have no idea.
Boowho??
boowho is offline   Reply With Quote
Old 04-13-2013, 05:54 PM   #12
Oops
Here's the file
Old 04-14-2013, 11:02 AM   #13
Herk7769's Avatar
4 six volt batteries should be wired like this.
NOTE: ALL wires (except the ones going to the coach) should be EXACTLY the same length and Gauge.
Corrected your diagram for correct wiring sequence:
Also Ditto on the shorted cell...
HAM CALLSIGN - KC3FFW
Old 04-14-2013, 12:06 PM   #14
Wait a sec, Herk..... The extra circuit into the house is how it came from the factory. I mean FR made two circuits out of it going into the house for a reason, right? I can't very well leave one off and dangling loose.
Boowho??
Old 04-14-2013, 12:51 PM   #15
Herk7769's Avatar
Boowho??
Before I answer that I need a photo if at all possible. If there are two different circuits, there should be no "ties" between the "battery sets." If there is ONE circuit, then there should be only one ground and one hot from the camper's converter.
Do you have an INVERTER? Perhaps one set of wires goes to an inverter and not the converter/charger.
Having two separate "plus" lines and two separate "ground" lines and then tying them together at different battery posts makes no sense to me.
Wait! I just looked up your camper. You have a Berkshire motorhome.
Maybe one set goes to the motor's alternator or generator so both are not charging at the same time...
Old 04-14-2013, 01:32 PM   #16
I DO have an inverter and I'll bet that's what the second circuit is for.
OR it's as you say one for the alternator, one for charging from shore power.
Boowho??
Old 04-14-2013, 01:49 PM   #17
Herk7769's Avatar
Boowho??
If it is indeed the Inverter, it would make more sense to have both grounds on one battery and both positive leads on the opposite farthest battery as indicated in my modified picture.
Old 04-14-2013, 02:12 PM   #18
Electrically, what is the difference between these two drawings? My knowledge of electricity tells me there is no difference. But obviously I can always learn something new.
Along that same thought, why is it that the jumpers all be the same length? If they are copper, resistance would be negligible I should think. I can understand being the same gauge, but not the requirement they be exactly the same lenghth.
Boowho??
Old 04-14-2013, 02:32 PM   #19
Herk7769's Avatar
The electrical resistance between the Positive and Negative end points is not "negligible" when you are charging or discharging the batteries when you consider that one battery (set in your case) will work harder than the other at all times. That will lead to early failure of one battery set (could be why you are having problems).
This is how 2 12 volt batteries should be connected to balance the current into and out of a bank.
Name:	Battery Parralell Connections.jpg
File Type: pdf How to correctly interconnect multiple batteries to form one larger bank.pdf (106.1 KB, 12 views)
Old 04-14-2013, 03:19 PM   #20
VinceU's Avatar
Here's the file
Just wondering, can those output leads be doubled to allow for the high current? IE: if the AWG is small but doubled to carry all the ampacity the batteries can deliver vs single heavy cables each polarity?
