Old 04-14-2013, 04:25 PM   #21
Herk7769's Avatar
Originally Posted by VinceU View Post
Just wondering, can those output leads be doubled to allow for the high current? IE: if the AWG is small but doubled to carry all the ampacity the batteries can deliver vs single heavy cables each polarity?
Vince,
I am not sure what you are driving at. His issue is not with the current out of the stack, but the unbalanced resistance of the batteries.
HAM CALLSIGN - KC3FFW
Old 04-14-2013, 05:26 PM   #22
Originally Posted by herk7769 View Post
The electrical resistance between the Positive and Negative end points is not "negligible" when you are charging or discharging the batteries when you consider that one battery (set in your case) will work harder than the other at all times. That will lead to early failure of one battery set (could be why you are having problems).
This is how 2 12 volt batteries should be connected to balance the current into and out of a bank.
After reading your PDF file I could only say to myself "Well, I'll be damned".
I never would have thought that it could make that much difference. Maybe that IS my problem, although I'm not sure what I could do to get them more balanced. I'll think about it.
Thanks for sharing.
Boowho??
boowho is offline   Reply With Quote
Old 04-14-2013, 06:08 PM   #23
VinceU's Avatar
That's why I started "just wondering"
That said seems the coach is three years old already and Boohoo is a full timer. If the batteries have been "on charge" most of that time, regardless of the wiring its not unusual for a battery to sulfate and eventually short out.
Still don't know where the four leads go, if all to the same power control center for solenoid control as most coach designs do, it would seem to me the wiring is goofy but perhaps two each pole was necessary to carry the current. Gotta believe the coach batteries are switched from the chassis batteries via the Intellic or SDC control panels.
Most of all the system survived for 3 years, they must have done something right?
Must admit that is some strange wiring, anybody with a Berkshire see the same?
Old 04-14-2013, 06:42 PM   #24
I bought the coach last November. It was "used" (titled) but never taken out. Original owner bought it August of 2011.
He did charge the batteries off the generator periodically; I don't know how often. Knowing him, it was probably at least twice a month. With only 3072 miles on the chassis but 49 hours on the genset, I'd say fairly often.
Manufactured date late 2010 or early 2011. Chassis came off FL line in Oct 2010.
In reading Herk's PDF file (I'm still stunned to learn what was in there), maybe I should just move the two pos inputs to the coach to one end of the stack (same pos post) and then move the two neg inputs to the same post on the other end of the stack (same neg post).
That way I'd be about as balanced as I can get. Still I'd be a little worried about by FR did it that way (as shown in my original pic) in the first place.
Boowho??
Old 04-14-2013, 06:54 PM   #25
Herk7769's Avatar
Boowho??
Do motor homes come stock with 4 six volt house batteries?
Maybe the original owner had them installed by a local shop.
Old 04-14-2013, 07:09 PM   #26
I don't they were installed after delivery. The tray EXACTLY fits four batteries, and I believe that bigger coaches like this (DP) probably have 4x6 as standard equipment.
Plus if he had them installed later, the paperwork would have been in the stuff he gave me. He was extremely fastidious about such things; to the point of being a nit picker
Boowoh??
Old 04-14-2013, 07:23 PM   #27
VinceU's Avatar
I've seen it advertised in DP chassis, someone else in the forum with a 10 or 11 Berk commented on changing them. From memory they are on a slideout tray, nice setup. Anyway Boohoo has confirmed they are at least 3 years old, and we all know 30 minute charges a few times may not enough. Maybe change the cables and see what happens, that one battery is probably gone, I've had it happen over the years but only had to change one at a time.
Old 04-14-2013, 08:02 PM   #28
Well, if I only have to buy ONE that will be good news. I thought I read once before that the entire array (all bats) needed to swapped out at the same time.
Boowho??
Old 04-14-2013, 08:10 PM   #29
Herk7769's Avatar
Boowho??
That is my understanding as well.
As I understand it having a new battery and a older battery in the same cell will lead to a reduction in combined capacity due to a variance in the number of cycles between them. The stronger battery will self discharge into the older battery.
Here is an article that shows the reduction in capacity due to charge/discharge cycles.
Name:	battery Life as a function of charge discharge cycles.jpg
Old 04-14-2013, 08:17 PM   #30
VinceU's Avatar
Boowho??
Sorry, what I meant was heretofore that's all I had, one Group 24 battery for coach, one chassis start battery. By the way, the start batteries always far outlast the coach batteries. That's in both Class A and C motorhomes. This present one has two large coach batteries size 27 I think and one standard Ford chassis start battery.
