Old 04-13-2013, 04:18 PM   #1
Need battery expert
HI:
I have the usual arrangement of (4) 6 Volt house batteries, first two of them are connected in series to give 12 volts, the other two the same.
Then each pair of 12 volt bats are connected in parallel to give double the amp hours.
The problem is that one (and ONLY one) boils off liquid at a pretty good rate, while the other 3 lose almost no electrolyte at all.
I assume this indicates something wrong with the one battery like an internal short or something of that sort.
Am I wrong? Anything else I should look at??
Boowho??
boowho is offline   Reply With Quote
Old 04-13-2013, 04:24 PM   #2
BigTJohn's Avatar
Check for a dead cell or poor connection. Other than that, change the position of that battery in the line up and see it is still the same battery that boils water. If not, there is a setup problem, it it is the same batt then get a replacement.
Brenda and John
Master Blaster of the Navy
BigTJohn is offline   Reply With Quote
Old 04-13-2013, 04:27 PM   #3
Stanleyg's Avatar
How do you have the charger set up on them? You should have it set up so the positive is off the first battery and the beget ice should be off the last battery. This charges and draws voltage off all the batteries at the same amount.
Stan, Wanda, Sheray, Alex, Nicky, and Macky(the Chorky).
2013 Prime Time Avenger 33BHS
Stanleyg is offline   Reply With Quote
Old 04-13-2013, 04:30 PM   #4
Triguy's Avatar
Where in the battery order is that battery that boils off liquid the fastest?
Scott
DW, 3 Kids and our Goldens
2012 Shamrock 233S
2008 Toyota Sequoia 5.7L 4WD
Old 04-13-2013, 04:30 PM   #5
shabbona north's Avatar
Do you loose fluid while charging or while using them?
shabbona north is offline   Reply With Quote
Old 04-13-2013, 04:44 PM   #6
RPAspey's Avatar
have the battery tested, first you can do a specific gravity test, if ok - which I doubt, then load test. I'll bet you have a bad cell. It won't matter what position it's in, it'll still boil off.
2000 Cherokee 29BH with 6V batteries, LED lights & 400 watts of solar power, flipped axles and raised. 2007 Tundra 5.7L DC-LB with lots of mods. C-co, 8/158th AVN Maint.
RPAspey is offline   Reply With Quote
Old 04-13-2013, 04:59 PM   #7
Triguy's Avatar
boowho,
Page 17 of this manual from Trojan describes some troubleshooting techniques, including how to measure specific gravity as mentioned above.
Scott
2012 Shamrock 233S
Old 04-13-2013, 05:27 PM   #8
Stanleyg's Avatar
Beget ice = negative. Damn auto correct.
Old 04-13-2013, 05:34 PM   #9
VinceU's Avatar
Originally Posted by boowho View Post
HI:
Boowho??
Sounds like the one battery is cooked, literally. You could remove it and have a battery distributor do a load test on it as suggested. My guess is you need to have the one renewed at least, many others will say they should be changed together as an equal set. Worst can happed the battery will fail and you'll be down to one bank. Maybe start with the test? A lot will depend on how old and heavily used.
Old 04-13-2013, 05:42 PM   #10
Denver, CO
garbonz's Avatar
Bad cell would use less water methinks, so sump ting else is happening, but testing is the only way to figure it out.
2017 Fuse 23T
