Originally Posted by Converted
My 388V16 has 2 battery banks and multiple connections to chassis ground. I was also pondering how to connect a shunt. I suppose if you lifted the ground cable from the battery and connect that to the load side of the shunt then added a jumper (same gauge wire) from the battery negative to the line side of the shunt you will capture the load the battery is serving.
Thanks! That solution occurred to me, but don't see a simple (relatively) way of routing the secondary leads into the converter area.
After some thought. I bought a volt amp with a hall sensor. I can drop that "toroid" over the B+ and move on. Too simple...
I think? Thought the other was "too simple" too.
The cheapo shunts have a short life span due to heat cycling. The toroid may live longer. No isolator required.
Shunts in B+ can be a bit dangerous...
Thanks again!
I'll post the outcome/end result.
