Old 10-08-2016, 01:41 AM   #1
Need help asap, no slides
Ok I was overseas for 1.5 years and before i left i was having electrical problems like batteries wouldn't charge and even manual charging batteries the lights didn't work nor the control panel to check tanks. I got back and set up camper and everything seems to work on shore power except slides, leveling system and awning. I had the level working a little in truck power but nothing now. And now I'm stuck cause cannot leave campgrounds until stuff is fixed
pavetim is offline   Reply With Quote
Old 10-08-2016, 02:26 AM   #2
Oh figures it out, micro breaker popped. Still getting low voltage and clicking on pump motor when I try to level tho
Old 10-08-2016, 05:16 AM   #3
rattleNsmoke's Avatar
If you haven't already done so, replace your battery(s).
1988 Harley Softail Custom "The Fireman"
rattleNsmoke is offline   Reply With Quote
Old 10-08-2016, 09:15 AM   #4
I don't have batteries yet just running off shore power or hookedcuo with truck running. It even does it with shore power
Old 10-08-2016, 09:38 AM   #5
B and B's Avatar
Hello,
The convertor does not have enough current to run slides etc properly. The TV should be plugged in and running to make sure the charge line is working to help.
I would suggest you get batteries ASAP as the low voltage/current will cause issues with the motors and possibly burn them out.
Old 10-08-2016, 09:39 AM   #6
toslow's Avatar
becarful not to fry the alternator in your truck if your trying to charge dead batteries in the TT
haven a blast
toslow is offline   Reply With Quote
Old 10-08-2016, 09:40 AM   #7
B and B's Avatar
Also you need a battery to be safe on he road. Your breakaway will not work if the trailer becomes detached. In some if not all states/provinces it is against the law.
Old 10-08-2016, 09:59 AM   #8
Location: Minnesota ( wishing we were boondocking in the New York Catskills )
X2 to what B and B and toslow said ...
If your battery has been sitting idle, for 1.5 years, it could likely be "sulfated" or otherwise not able to take a charge / come up to full voltage. There are other possible explanations but same symptom / problem.
The "tech" of it is, there isn't enough current, figuratively enough water pressure coming out of the pipe if you will, to spin those motors under their full load. The motors will try harder but with the low voltage, they will draw more current, which will heat the wire in them more than design spec, and can cause failure (expensive repairs.)
The fact you ate (blew) a fuse (circuit breaker) supports the low voltage theory. This is a protection feature operating as designed.
The service manuals will indicate that the mechanism "may" operate under the lower voltages but also say that there will be increased current and problems as just noted above. In some cases (i.e. trying to use "jumper cables" or just the converter,) there will not be sufficient current.
The 12 volt connection from the truck to the camper has similar issues, voltage drop (length of relatively thin wire) and low current availability (relatively thin wire.) Think of how thick the primary wire is from truck battery to chassis and starter.
You could temporarily swap battery from TV to the Camper, BEING CAREFUL ABOUT POLARITY + / - connections of course, and that could provide enough electricity to get the sliders back in. Again figuratively, this is like using a fatter, shorter hose instead of a long, skinny garden hose, you get more water.
There are also manual methods for getting the slides and awning retracted; our chassis manual does not have info the levelers. Actually found "youtube" videos of some slide and awning procedures.
Best Luck ...
Jeff and Abby
Fur Babies - Xandra Sophia (GSD) and Neo (Min-Pin Mutt who thinks he is a cat)
2015 Tracer Air 235 (previous 1994 Veri-Lite 1130 TC)
1998 Dodge Ram 2500 Quad Cab - 360 - 46RE (Built)
Jeff_and_Abby is offline   Reply With Quote
Old 10-08-2016, 11:34 AM   #9
As I have said I don't have batteries, I will get them once I settle in here. What's that about the tv? Tv works fine, I noticed too when slides put strain on the motor I wants to kill the power. I am thinking it's the converter as I learn more how it works.
Old 10-08-2016, 11:46 AM   #10
Witch Doctor's Avatar
First you need a good battery, second do you have a multi meter? I will attach a trouble shooting guide for a WFCO converter not sure which you have but pretty much the same for a progressive. The size of the wire from the TV is not big enough to carry all the amps you need...Lets see if I can attach them so you will have a look.
File Type: pdf WFCO_WF_-_8935,8945,8955_Power_Converter_Manual.pdf (2.53 MB, 61 views)
Rockwood #8289 WS 2012
F250 6.0 / Husky 16k
With 4 point leveling system
slide
