Old 10-04-2016, 08:26 PM   #11
Cyber Phrenologist
Radio's Avatar
I asked the service department at my Ford dealer the same question about my F-150 when I was in for an oil change. I wanted two wires for my tranny gauge:
1. ignition on power
2. instrument cluster dimmer power (for the bulb)
They asked about 7 different mechanics and one of them finally knew off the top of his head. Alas, that was 2008 and I have forgotten the wire and tracer colors the guy gave me. But the dealer should have some one who knows.
KU4OJ
Admin at www.openroadsradio.net, part of the Social Knowledge network.
"RVing and Amateur Radio served up on the same plate"
2008 (or is it 2009?) Rockwood 8280SS - 2007 F-150
Radio is offline   Reply With Quote
Old 10-04-2016, 08:36 PM   #12
VinceU's Avatar
In lieu of paralleling an existing circuit, you may overload.... Go back under the steering column (DC buss) and choose a open fused connection marked IGN and use that. Chose fuse rating to serve your load.
Old 10-05-2016, 07:20 AM   #13
Wolverine 1945's Avatar
Originally Posted by HONDAMAN174 View Post
I do not own e-450 but if I was going to I would run a jumper off of cig lighter. Depending on what needs to be run and if it does turn off with key off-some (GM) do not.
2014 Evo 2850 "Woodstock"
2011 Toyota Tundra "Clifford"
Cigarette Lighter ???
Been a lot of years since I have seen one of those in a Truck or Car !!!
Or even an ash tray !!!
Wolverine 1945 is offline   Reply With Quote
Old 10-05-2016, 12:27 PM   #14
They are now called "Power Points".
Bob
2013 Ford F250 SD 6.7L
2014 Wildwood Heritage Glen 282RK
Certified Rumble Strip Tester
retiredcamper47 is online now   Reply With Quote
