Old 10-03-2016, 09:16 AM   #1
ilmor's Avatar
Need Help Finding Wire Connection - E-450
Hey all,
By any chance does anyone know of, or how to find, an easily accessible wire that is powered on and off when the ignition is on and off? 2016 E-450 chassis.
Thanks!
2017 Forest River Sunseeker 2250SLE
ilmor is offline   Reply With Quote
Old 10-03-2016, 09:53 AM   #2
HONDAMAN174's Avatar
I do not own e-450 but if I was going to I would run a jumper off of cig lighter. Depending on what needs to be run and if it does turn off with key off-some (GM) do not.
2014 Evo 2850 "Woodstock"
2011 Toyota Tundra "Clifford"
Just glad to get away
HONDAMAN174 is online now   Reply With Quote
Old 10-03-2016, 10:02 AM   #3
SeaDog's Avatar
below the steering wheel to the side of where the fuses are there are four wires color coded that are for the uplifter switches any of these are hot with the key
Retired Navy
Jake my sidekick (yellow Lab)
2006 F350 6.0
2016 Flagstaff 26 FKWS
AF&AM of Idaho
Old 10-03-2016, 01:49 PM   #4
ilmor's Avatar
In the Fords the cig lighters are always on. But thanks I appreciate!
Old 10-03-2016, 01:50 PM   #5
ilmor's Avatar
I'm not sure what those would look like, but I'll see if I can figure it out. Thanks!
Old 10-03-2016, 02:01 PM   #6
Emergency brake switch
Davidjeff is offline   Reply With Quote
Old 10-03-2016, 02:04 PM   #7
ilmor's Avatar
Ok there's a good thought. Thanks!
Old 10-03-2016, 03:15 PM   #8
Find the fuse box under the dash and use a 12v test light. 1) Find an empty fuse slot and test it with the test light. Auto parts stores sell a fuse device that has a wire coming off of it. The fuse part goes into the slot and attach your device's feed wire to the wire coming off the fuse. That is how I wired my dash cam in my truck.
Bob
2013 Ford F250 SD 6.7L
2014 Wildwood Heritage Glen 282RK
Certified Rumble Strip Tester
retiredcamper47 is offline   Reply With Quote
Old 10-03-2016, 04:11 PM   #9
The only problem with the adapter retired camper suggests is the newer Fords pin spades in the BCM (fuse box) are very weak and will spread creating a poor connection in the future especially if you delete it later and put just the fuse back in. Find a good source and solder your connections as scotchlocks are poor connectors as well
Old 10-04-2016, 08:01 PM   #10
IF your 450 came with the factory installed 7-way Bargman plug then one of the wires in it should be hot. That pin would be labeled (+) and should be hot when the ignition is turned on.
Thurman is offline   Reply With Quote
