Closed Thread
Old 04-09-2016, 03:14 PM   #21
270S's Avatar
Also, a real biggie overlooked by 99.99% is wire size. I will be using 0000 (said "4 aught"). It is 3/4" in diameter with insulation. There will not be any voltage drop and efficiency will be as close to 100% for transmission as possible.
'17 270S
270S is offline
Old 04-09-2016, 03:20 PM   #22
[QUOTE=spock123;1158553]I wish I had not took the pictures of the batteries. ... I don't need any advice on the batteries
It's the political season and no one actually answers the question posed! You can always put more than one lug on a battery terminal, done all the time. I don't however understand the "drilling holes"part of the question. I assume that inside the inverter, both of those lugs go to the same bus bar anyway.
Now what was the question again??????
2015 335DS
ScottBrownstein is offline
Old 04-09-2016, 03:39 PM   #23
Kenny kustom's Avatar
Need help on wiring inverter and charger to 4 six volt batteries
Originally Posted by spock123 View Post
I wish I had not took the pictures of the batteries. That was not what I was asking about. I have been hooking up batteries for ten years or more. Just forget the batteries. It was really the inverter because of the two positive cables. I don't need any advice on the batteries
Don't be snooty.
Members saw the knife switches, lack of fusing, scary wiring and thought you needed some help.
2016 Sabre 36QBOK
2015 Ram 3500 CUMMINS
2017 Dynamax Isata 4
Kenny kustom is offline
Old 04-09-2016, 04:01 PM   #24
Originally Posted by Kenny kustom View Post
Don't be snooty.
2016 Sabre 36QBOK
I have did it before I just had more battery post to work with. I like the knife switches. If everything is hooked up right you don't ever get a short. I check all my wiring three or four time before I hook up the negative post. I may go on Amazon and find some 2 AWG. I'm going to hook up the inverter two positive cables to one post on the knife switch, then I'll only have three cables on one battery post. The camper came with four six volt batteries and the cable on them is four or more. They worked after I wired them up correct.
2015 Cedar Creek 32RL
2012 Silverado 3500HD SRW
http://www.forestriverforums.com/for...ignhavefun.gif
spock123 is offline
Old 04-09-2016, 04:08 PM   #25
I cant see the terminals, but it looks like the batteries are in series giving 24 V , wire like the previous posts
Big Bill is offline
Old 04-09-2016, 04:17 PM   #26
They are 6 volt batteries wired correctly, series/parallel giving 12 volts.
2007 Surveyor SV230
- 200 Watts Solar/MPPT Controller - 230 AH Battery Bank - 600 watt PSW Inverter - (2) 2000 watt Inverter Generators - LED Lighting
Boon Docking 99% of the time.
2009 F150 - 5.4 Litre - Tow Package
boondocking is online now
Old 04-09-2016, 04:21 PM   #27
Put as many on one post as you want, as long as they fit it's no problem.
2015 335DS
Old 04-09-2016, 04:43 PM   #28
270S's Avatar
NO it is Not correct to load up ANY post with more than a single wire, 2 if continuing on, but even then ....The proper way is to use a bus bar. Connect each item on the bus bar that is part of the same parallel circuitry. To do otherwise invites galvanic corrosion (shows up as green slime). Is what you were asking answered?
'17 270S
270S is offline
Old 04-09-2016, 05:11 PM   #29
Now I know why you were asking the question. I don't know where you got that as I certainly have never seen it. "If you are going on..." where else would you be going. There are standard battery schematics that have 3 wires on one post otherwise you cannot get equal length circuits for parallel batteries, like say 4-12 volt batteries.
Obviously you can get galvanic action on any lug and post combination.
2015 335DS
Old 04-09-2016, 05:36 PM   #30
The_Rhino's Avatar
Don't be snooty. Members saw the knife switches, lack of fusing, scary wiring and thought you needed some help.
Yes, folks are just trying to help you create a safe, efficient setup... Accidently drop a tool across all those knife switches & the sparks will fly! Also, the wires are too small to handle the amps possible from (4) 6V batteries... IMO you need to see a good (4) battery installation on a MH & use that as your build guide... Much heavier 12V wires are used, fuses, and everything absolutely secured so that a fender-bender does not cause a fire...
I have a good understanding of DC voltage from my RC aircraft & Ham radio hobbies... DC can push the amps & do a lot of damage so it's important to always use fuses immediately after the batteries, install heat shrink tubing over bare wires, etc. You need to be SAFE around DC w/amps just like 110V AC... It can kill ya...
However, I also still have a lot to learn when it comes to RV applications. As I am planning to install a residential fridge powered by an inverter, I had no idea I would need to consider using welding cables for the DC side until I read these forums... So I plan to gather as much info from others on these forums before I finalize my build plans.
2011 RAM 2500 ST Crew Cab 5.7 Hemi ($14K in '13)
2011 Primetime 3150BHD Touring Edition ($20K in '14)
Days camped in 2017-31
2016-36; 2015-37; 2014-31
The_Rhino is offline
Closed Thread
inverter, wiring, battery
