Old 07-03-2015, 03:29 PM   #31
Okay,now I believe in jinxes! Just yesterday I was saying that we've had no major problems with our Sunseeker on another forum, and today I have no 120 v electric! The pedestal is okay according to my (better than) surge protector, and every thing works on generator. The Forest River tech I called said it sounds like either the cord or the transfer switch. The FR dealer near here in Sheridan hasn't returned my voice mails- he may be closed for the holiday weekend. We're still on warranty so I'd like to have him fix it! Any ideas on any thing I can do, other than run the genny? Thanks.
2014 Sunseeker
3170ds (Suzuki Samurai 1986 toad)
Gary and Dottie, fur babies Doodle(corgi) and Beau(yellow lab)
Yorkranchgalnguy is offline   Reply With Quote
Old 07-03-2015, 04:57 PM   #32
7 Year Class A RV'er
Have you tried removing the surge protector and seeing if you get power? If you get power that way, then there is a jumper wire you can use inside the surge protector to bypass it's "brain" and make the switch kick over. If it's hardwired, then open the cover on the transfer switch (beware of hot wires!) and find where the shore power cord enters the box. If you're 50A, there will be three wires. The center is the common and the two outer wires are hot. Check voltage between each of the two hot wires and the common; you should see 120V on each of those legs. If you're 30A, you'll only see two wires going into the relay, so check voltage across those and you should also see 120V. There is an additional wire in the shore cord but it's a ground and should be connected to a grounding screw on the side of the surge protector frame inside. Please post as to whether or not this works so I'll know if I need to keep researching. Thanks. Good luck!
2015 Legacy SR340 360RB
Old 07-03-2015, 08:38 PM   #33
Yep, tech had me remove surge protector and plu in cord: still no 120 v power. So either cord or transfer switch, which I know nothing about or even where it is! I'll be fine til Monday when I expect to hear from the dealer in Sheridan. Thank you for your suggestions and for any other ideas you might have!
2014 Sunseeker
Old 07-03-2015, 09:17 PM   #34
Transfer switch may be located under the bed. If you can find it, try giving it a good thump with a shoe or rubber mallet. Might jar it loose.
Old 07-04-2015, 12:50 PM   #35
Okay-this am I turned on the generator on to make coffee and cool the MH down. It ran fine for about an hour (it only has 79 hours on it) then it stopped, tried to start several times- it would start then run down and stop. Turned cab on still no joy! So, I'm on 12v until I can get ahold of Dalton's RV in Sheridan on Mon. First time boondocking even if I'm in a CG! I'll survive! Thank God for propane. I guess I should be thankful we're still under warranty also. Thanks for letting me vent!
2014 Sunseeker
Old 07-04-2015, 01:54 PM   #36
Check you fuel level; close to 1/4 tank? If so, that's the issue. You may be at a slight angle, just enough to get the gas level below the generator fuel intake.
Old 07-07-2015, 03:19 PM   #37
Got to Dalton's rv and eventually they found the problem. At first they thought it was the transfer switch because it didn't have power to one side, so they took it out of the loop so I could use 120 only,til they could get a new swthch$$$. But there was stil no 120! So they found a loose connection right at the wall plug, which had probably been loose from the factory, tightened that , and voila 120 and the switch worked! They also found a loose wire set for the 12v that had no wire nut and fixed that.I will be sending the $127 bill to FR warranty.
2014 Sunseeker
