Old 09-20-2015, 01:33 PM   #1
need help - where is gfci reset?
2015 cardinal model 3825 - somehow this morning it looks like we tripped a gfci circuit protector. we have three outlets in the kitchen that all have a little sticker on them that say 'gfci protected outlet'. they are normal outlets with this sticker on them. they do not have the gfci test or reset buttons on them. this implies to me that there is another device somewhere that has tripped knocking out power to these outlets. i have gone to the 110 volt distribution panel and checked and reset the circuit breakers. there has to be a gfci device between the circuit breaker and the gfci protected outlets. does anybody have any idea where it might be hiding? I have looked under the sink and in all the places that are obvious to me. can't find it. since it should have a reset button on it, it should be accessible. any ideas are appreciated.
CHICKDOE is offline   Reply With Quote
Old 09-20-2015, 01:38 PM   #2
Ford Idaho's Avatar
Bathroom?
Mine is on the entry side of the kitchen counter, it has a brown cover plate.
Old 09-20-2015, 02:03 PM   #3
WolfWhistle's Avatar
Did someone put a 6 way cover over it?
WW
Hyper diaper 29HFS = 2015
2017 F-250 4x4 6.2L Gas
Old 09-20-2015, 03:13 PM   #4
Head Rambler
Gfci's can be located anywhere in the RV. I've seen them outside, inside near the kitchen, in the bathroom and even in the bedroom. Just look at every receptacle in and out of the unit.
Gotta go campin!
Old 09-20-2015, 03:33 PM   #5
Scubanut's Avatar
Check the outside outlet, that is where mine is.
2012 F150 FX4 Crew 5.0
2012 Coachman Freedom Express 292BHDS (outdoor Kitchen)
Scubanut is offline   Reply With Quote
Old 09-20-2015, 03:41 PM   #6
Mr. Dan's Avatar
Mine is 12" left of my bathroom sink and only a few inches off the counter - the perfect place for water to splash on it which SHOULD trip it every time. We have to be careful.
Sent (I think)
SEARCH is your friend!
Nights Camped: '13 = 49 / '14 = 74 / '15 = 74 / '16 = 85 / '17 = 110 / '18 = 28; booked = 34
Old 09-20-2015, 05:03 PM   #7
found it! thanks. the receptacle in the bathroom has the test and reset buttons. turns out this receptacle also controls the three in the kitchen that went out. thanks for all the replies. and as somebody said, I am learning that stuff can be located anywhere. I still have other things to track down. again thanks
Old 09-21-2015, 04:58 PM   #8
Wait until you try to locate the crank handle that operates the slide out when it is inoperative.
saltyman is offline   Reply With Quote
Old 09-21-2015, 07:42 PM   #9
Better know how to operate the slide now, when you have time not when an inopportune moment strikes. Mine doesn't have a crank...that would be too easy
