Old 07-15-2015, 07:46 AM   #11
Flybob's Avatar
If you want to check the condition of the batteries, you need do so after being disconnected from the charger ( convertor) for about 24hrs. Use the chart below to determine state of charge or better yet get a hydrometer ( inexpensive)
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 07-15-2015, 07:33 PM   #12
Thank you Flybob! I will do that. Can I also use that chart to check the batteries after they have been powering a few devices or do I need to totally disconnect from charger and TT to confirm the condition?
2014 Ford F-150
2015 Apex Nano 193BHS
2017 Nights Camped: 14
mbCik is offline   Reply With Quote
Old 07-15-2015, 07:55 PM   #13
Left Coast
Total disconnect and let 'em (it) set as it'll retain a surface charge that'll give you a false reading.....the load checker is really the way to go.
voltage
