Old 11-18-2019, 08:09 PM   #1
New 30 amp outlet in pole barn
Does anyone have a diagram to wire a 30 amp outlet in my pole barn to plug MH into during storage?
Retired and loving it
hdjimmi is offline   Reply With Quote
Old 11-18-2019, 08:34 PM   #2
Hatchdog's Avatar
Here you go, just did the same myself about a month ago and used this instruction sheet posted here by wmtire.
http://www.myrv.us/Imgs/PDF/30-amp%20Service.pdf
ID:	219419   Click image for larger version
2020 Rockwood Ultra-lite 2608BS TT
2011 F250 Lariat 6.2 gas 6 sp auto 3.73 rear 4X4 6.75í bed crew cab
Recurve R6 hitch
Hatchdog is offline   Reply With Quote
Old 11-19-2019, 01:50 AM   #3
It wont open ????
Old 11-19-2019, 01:52 AM   #4
I copied link... thanks. So it is not realy on a 220v circuit. Thanks much
Old 11-19-2019, 06:32 AM   #5
Oaklevel's Avatar
Go to the Library tab in this forum.... Lot of great info there...
Try here maybe this link will work ??
here or
Forest River Forums - Downloads - How to wire an RV 30 amp outlet
2005 Dodge 3500 Cummins
2017 Wildwood Lodge 4092 BFL
1966 Mustang GT
1986 Mustang SVO
Old 11-19-2019, 06:40 AM   #6
Oaklevel's Avatar
That is the big mistake many make. It is 110V if you put it on 220V you will loose most of you electrical appliances and converter in the camper.
1966 Mustang GT
1986 Mustang SVO
Old 11-19-2019, 07:08 AM   #7
Lacey's Spring, AL
formerFR's Avatar
an 'RV' 30amp outlet is simply the same type 120v power as your regular ordinary everyday household outlets, except that it uses slightly larger wire, and a 30amp breaker, of course - otherwise it's wired exactly the same. The 'PLUG' end is different, also, but it is NOT the same as a 240v dryer plug, since the two have a ground that are shaped differently.
30amp 120v power to your RV is not really much different than your normal household outlets, just more 'amps'.
The Turners
'14 Thor Palazzo 33.3 diesel
KingTailgater2 Dish, 100w/5amps roof SOLAR, BlueOx, 100,000+mi since '14... US, Alaska, and Canada... from W.C. Georgia, then W. North Carolina, now Lacey's Spring, AL : )
formerFR is offline   Reply With Quote
Old 11-19-2019, 07:13 AM   #8
Trailer Park Supervisor
NJKris's Avatar
Do you have 30 amps running out to the barn? I have only 20 amps running to my shed (never thought I would own an RV or would have run 30!). I used the same receptacle shown above to wire into my 20 amps in the shed. Works great! As long as you don't try running too many things at once. So nice to be able to run A/C if I want, or the electric heat strip.
NJKris is offline   Reply With Quote
Old 11-19-2019, 07:16 AM   #9
Lacey's Spring, AL
formerFR's Avatar
right, if the object is to simply have some power to keep the batteries charged, etc., then a requirement for a 'full 30amp outlet' is not needed....keep it simple, especially if you already have an outlet in the 'barn'... a 15amp household outlet will work just fine.
Old 11-19-2019, 07:27 AM   #10
NJKris's Avatar
The outlet is nice even if you can only run 20 amps to it, this way I can use the heavy shore power cord and never worry about 15 amp adaptors or a lighter cord overheating.
Old 11-19-2019, 10:16 AM   #11
Hatchdog's Avatar
+1 to the above and another reason I did this was to put a 30 amp surge protector in-line. Cost was minimal with the largest cost being the wire because I needed/wanted to run 50í for convenient access to the cord location on my trailer.
Recurve R6 hitch
Old 11-19-2019, 10:22 AM   #12
NJKris's Avatar
Hatchdog, I do the same thing. My Progressive EMS shows current draw too, helped me get a feel for what is drawing what without going over my 20 amp limit to my shed sub panel.
Old 11-19-2019, 01:34 PM   #13
DouglasReid's Avatar
NO, it IS NOT a 240 circuit, you will fry Everything in the camper if it is hooked up as a 240 Volt
2008 Chevy Silverado 2500HD CCSB LTZ Diesel, Fumoto Oil Drain Valve, Turbo Brake activated, 39 gal Aux Tank W/ Fuel Pump transfer, Air Lift Loadlifter 5000 air bags.
DouglasReid is offline   Reply With Quote
Old 11-19-2019, 01:34 PM   #14
Who makes you surge protector kind sir???
Portagie1968 is offline   Reply With Quote
Old 11-19-2019, 01:39 PM   #15
Fulltime family RVer
You want more than just a "surge protector". Progressive Industries or SurgeGuard both make electric monitoring/management systems.
More info:
https://learntorv.com/what-surge-pro...est-for-my-rv/
Old 11-19-2019, 02:08 PM   #16
SailorSam20500's Avatar
At this years FR International Rally, Mike Sokol gave a talk. Based on the products currently available, he recommends the Surge Guard product. Nothing wrong with the Progressive product which for many years was the best on the market. However, original owners of Progressive sold to another company a couple years back. Mike said that the new company isn't investing as much R&D as Surge Guard and as a result, Surge Guard has displaced them.
For the record, I have a Progessive unit and am happy with it.
Al
Save the Earth. Itís the only known planet with Beer.
S.E. Mich.
Flagstaff 26FKWS / 2019 F-150 3.5 EcoBoost SCrew
SailorSam20500 is offline   Reply With Quote
Old 11-19-2019, 04:09 PM   #17
Hatchdog's Avatar
Itís a Camco I found on Amazon. As ependydad stated I do have a 50 amp Surgeguard I use in campgrounds. This cheapie Camco is just for home use as I know my power is sound.
https://www.amazon.com/Camco-PowerDe...pcontext&psc=1
Recurve R6 hitch
Old 11-19-2019, 04:16 PM   #18
More info:
Thank you. Can I ask what the yellow apparatus your rig is plugged into. Where do I get it?
Old 11-19-2019, 07:08 PM   #19
Hatchdog's Avatar
If you are speaking of my picture the yellow item is the Camco surge protector. See my post #17 for an Amazon link to it. I got mine from Amazon for convience but Iím sure they are available at your local RV store.
Recurve R6 hitch
Old 11-19-2019, 08:25 PM   #20
OCD Tech's Avatar
This is 110% True. Oh, and ruin a good camping trip.
OCD Tech is offline   Reply With Quote
