Old 02-11-2015, 10:33 PM   #1
New camper and no power!
Hi everyone! Been on here for awhile reading and looking around, but this is my first post. I am needing some help!!
I have done the tent camping for years, but it is really starting to hurt sleeping on the ground. So I decided it was time for a camper for the family. We got a 2015 Gray Wolf 26BH.
Here is my problem! Picked up the camper today, and got it home. Everything worked great during our walkthrough, and after we got home, but a few hours after getting home I go back out to play with my new toy, and I have no power to nothing. It is dead! Do you know what could be causing this?
All this stuff is new to me so I am thankful for any help you may have!
The Peddler is offline   Reply With Quote
Old 02-11-2015, 10:38 PM   #2
WFD
Check your breaker marked "Main" in the breaker panel. Dealer may have switched it off before disconnecting power to the trailer. My dealer recommended we do this everytime before turning the power off to the trailer.
Now when you say no power, your lights aren't even working?? Those should be feeding off your battery.
2016 Chevy Silverado 2500 Duramax
2016 Rockwood 8289WS, Diamond Pkg.
WFD is offline   Reply With Quote
Old 02-11-2015, 10:44 PM   #3
I check the breakers and they are good. Yeah I have no power to anything, lights, jack, awning, nothing.
Old 02-11-2015, 11:00 PM   #4
Kaadk's Avatar
All those run off the battery. Do you know if you have a battery disconnect? In my trailer it's a plunger like knob near the breakers. When it's pushed in it shuts off the battery. You need to pull it out for everything to work.
Barring that, it might be an issue right off the main line. From the battery, trace the line from the positive back under the trailer. It should go to either a fuse or a small block with two posts on it. If it's a fuse, check to make sure it's ok. If it's a block, look for a small button sticking out the side. That's the reset. Push it back in.
Let us know if none of that works and we'll look at whatever else we can.
The surest way to lose is to play Marco Polo with a ventriloquist.
Old 02-12-2015, 12:56 AM   #5
asquared's Avatar
First check to make sure the battery connections are tight. Look for a battery disconnect switch. On my fiver it is located in the basement right above the battery and is a red and white round knob that turns side to side from off to on. As suggested next would be to look for a fuse in the wires coming off the battery. Do you have the ability to plug into shore power where you are? If so do you have power when plugged into shore power?
<a href=http://i62.tinypic.com/28rp645.jpg target=_blank>http://i62.tinypic.com/28rp645.jpg</a>
2014 Sabre 34REQS-6
asquared is offline   Reply With Quote
Old 02-12-2015, 04:59 AM   #6
raspivey's Avatar
I had that problem on my first trailer..worked fine at the dealer, then nothing at the house. Come to find out, there was an inline fuse on the battery that wasn't installed. During the walkthrough, it was plugged in to 110 and the converter was supplying the 12V power, so I didn't notice. A battery disconnect will act the same way. I'm also assuming you didn't have it plugged in to shore power.
Old 02-12-2015, 09:23 AM   #7
Thanks for all the help guys!!
I got out this morning and plugged it up to the house and had full power. I left it plugged up about an hour, and then unplugged it, and still had full power. Could it have been something as simple as the battery was dead? If so is that normal for a new camper?
Old 02-12-2015, 10:11 AM   #8
It seems the battery was just dead. When you plugged it in that charged the battery some to give you power when you unplugged. I would put the battery on a charger/tester to make sure then charge it up. The battery may have been charged from the dealer but something left on after the walk through and drained the battery overnight.
2018 XLR Nitro 36T15
2015 GMC 3500 6.6/Allison
Nights Camped (2018-10) (2017-16) (2016-13) (2015-13)
SuicideSaints is offline   Reply With Quote
Old 02-12-2015, 10:33 AM   #9
KyDan's Avatar
Plug it back in for 24 hours to fully charge your battery.
If this happens again you will need to figure out what is draining your
battery so fast!
It's also possible the battery was mostly dead at the dealer.
He plugged you in to do the walk thru and it gave your battery a little
charge. Now it's dead again.... This is VERY hard on your battery.
First you need to plug in and let it fully charge.
Any trailer will drain the battery in week or two if the battery is left
on. Many do not have a battery shut off
Most of us here recommend adding a battery shut off switch if you
don't already have one.
I've had to add them to every one of my 4 trailers over the years.
They guy on ebay where I buy the switches knows my ebay id by heart!
Peace!
Dan & Rita D
Blue Ox WD hitch
Old 02-12-2015, 01:58 PM   #10
Send a message via MSN to Tiggerdad
Some trucks come from the factory without a 50 amp fuse. With out this fuse you trailer will not charge from the tow vehicle. Not a good thing as you need battery power for your safety disconnect should your trailer become disconnected from your vehicle. Without that battery being charged your trailer breaks would not engage
2013 Crusader 330 MKS
2013 Chevrolet Silverado LT 2500 D/A
Tiggerdad is offline   Reply With Quote
camper, power
