05-25-2018, 05:59 PM
New FW owner with a 7 Way Plug problem
My DW and I just purchased our first "adult sized" RV (we owned a couple of pop-ups in the past.) We purchased a lightly used 2014 Wildcat Maxx RK282. Today was the first day hooking it up to our 2007 Ram 2500 with a Superglide hitch and things went pretty well for a couple of newbies. Even got parked along side our driveway which is perpendicular to the street and a pretty tight fit. Let's just say that it's good we live on a street that has no through traffic and that our neighbors, by being at work, missed the opportunity to count how many times I pulled forward to get things lined up.
The only real problem was that I was unable to get the plug on our FW into the socket in the sidewall of the bed of the Ram. It seemed that the plug was too big to fit into the opening. I did verify that the form factor of six blades and a center post was matching on both plug and socket. Is there a chance that my plug is slightly bigger than the socket or some other change in form took place between 2007 & 2014? Any advice is welcome and thank you in advance. We're looking forward to our maiden voyage in a couple of weeks.
05-25-2018, 06:32 PM
Don't want to insult your intelligence as not sure of your experience level. Did you try to rotate the plug 180 degrees? The plug and receptacle are keyed. It'll only fit one way. Can you post pics?
_________________________
Crusader 337QBH
2019 F350 6.7L DRW CC LB 4x4 Lariat
B&W Companion 20K for OEM pucks.
05-25-2018, 06:37 PM
No insult taken.
I did make sure the "key" on the plug was oriented properly and the plug went in about 3/8". I'll snap some pictures later on and maybe that will reveal the issue. To my eye the plug and socket looked identical.
05-25-2018, 06:40 PM
Certified Curmudgeon
Only one size plug that I know of.
Mike Dropped
05-25-2018, 06:48 PM
Originally Posted by DuckNV
No insult taken.
Normally the cover of the receptacle has a small flange that engages the back of the plug preventing the plug from falling out unless you lift the cover. Is that engaging? If so then it's in all the way.
Crusader 337QBH
05-25-2018, 06:52 PM
I have had the tabs inside the plugs bend and also had one break preventing the plug to go in.
2015 Wildwood X-Lite 271RBXL
2019 Ford F350 CrewCab Diesel
(2013 Ford F150 Crewcab Ecoboost traded)
05-25-2018, 07:01 PM
here are the pictures.
I may have to find a smaller plug or make the one I have a little smaller
Looks like there may some bent tabs in there blocking my way.
05-25-2018, 07:02 PM
X2 - I had one blade in the receptacle out position a smidgen and that prevented the plug from going in. I forgot about that.
Crusader 337QBH
You have bent/damaged tabs. See post # 6.
05-25-2018, 07:05 PM
Definitely the one at 11 o'clock. Use a screwdriver to move that one half tab back out like the others.
Crusader 337QBH
05-25-2018, 07:07 PM
The one at 5 o'clock could be a problem too. Some of the others might be a little too spread apart too.
Crusader 337QBH
The one at 5 o'clock needs screwdriver work, also.
05-25-2018, 07:18 PM
I would just replace the plug on the fifth wheel. They are cheap and it's easy. That plug looks a little worse for wear and will probably cause you problems or arcing later.
Scott and Liz - Southern NM
2007 Chevy 2500HD Duramax
05-25-2018, 07:28 PM
X2 - good advise as always from NMWildcat!
Crusader 337QBH
05-25-2018, 07:44 PM
Replace it, it looks like it's been hot, I can see several spread apart, a couple look to be split, you might have been using it somehow where there was a little over current for whatever reason or it's possible it's just not a good quality product. That spring tension to keep connections tight is required for long life and safety.
Dalin...(Dan & Linda)
2018- Georgetown- 36B5 GT
Veteran USN / RD3 68-74
Retired Electrician, Miller Brewery, 31 yrs.
05-26-2018, 12:27 PM
advise
Looks like the pins are bad ...you can buy a new cord..open up the box and replace the cord...splice the wires one at a time color for color....
Save a beer for me!!! Happy Trails....Be Safe....
05-26-2018, 12:35 PM
We had the same problem with our Rockwood on the day we picked it up. Dealer did some trimming, filing, sanding and finally get it to go into the connector on my truck. I bought a decent connector and changed the trailer side and problem solved. Factory connector cheap and obviously wasn't a good fit.
Mike & Fay
2013 Rockwood 8289 Diamond with 3.5" lift
2017 GMC 2500HD Duramax
Curt A20 c/w GM Puck system
2021 56 night’s booked
05-26-2018, 01:02 PM
Not only the arcing but the annoying noise when the vehicle no longer detects the trailer so it beeps, then reconnects, then beeps, etc. etc. etc.
To insure you get it connected back correctly I cut off the leads from the old plug and then, matching the wires color for color, one at a time, I connect the new cable and plug.
Here is a diagram to tell you what each color does:
http://www.etrailer.com/Merchant2/gr...ver2_2_800.jpg
Use the center one for your RV
2009 Chevy Silverado 2500HD CCSB LTZ Diesel, Fumoto Oil Drain Valve, Turbo Brake activated, 39 gal Aux Tank W/ Fuel Pump transfer, Air Lift Loadlifter 5000 air bags.
05-26-2018, 01:23 PM
you have 3 damaged blades.
