Old 06-08-2014, 12:45 PM   #1
new guy, few questions,not sure if battery is charging
I just picked up my 2015 wolf pup 16bh. Everything works when plugged into shore power. Also when plugged into my truck for towing the lights, radio and water pump power on. But if im not plugged in i have nothing. Do i need to flip a switch or something to get it to run off the battery? It was a 4 hr ride home from the dealer so that should of charged it some. Also i had it plugged into my house power overnight. All fuses are good. Next step I will put a charger on the battery. Then I guess get out the multi meter and track it down. Im just hoping im missing something. Thanks
rynb15 is offline   Reply With Quote
Old 06-08-2014, 12:54 PM   #2
RSchleder's Avatar
I am not familiar with your exact RV, however, every Rv I've owned (12 units) have had an auto switching unit that switches between power sources. Your unit, I must assume, should also switch automatically, however, the switch could be defective.
RSchleder is offline   Reply With Quote
Old 06-08-2014, 01:21 PM   #3
DaGrinch's Avatar
Battery disconnect switched to "off" if so equipped? Maybe?
"Sunny" the 2017 Sunseeker 3010DS
2006 Jeep Liberty Toad
.... and lovin' life........MOST of the time.
DaGrinch is offline   Reply With Quote
Old 06-08-2014, 01:34 PM   #4
BamaBob's Avatar
X2! I accidentally did this when we picked up our 5er last year (our switch is right next to the battery and pretty easy to trip) took me 20 min of semi-paniced troubleshooting before I checked the disconnect switch
Nights Camped: 2013 - 24 2014 - 42 2015 - 56 Jul 2016 - Fulltime
BamaBob is offline   Reply With Quote
Old 06-08-2014, 03:06 PM   #5
Checked and did not see any type of switch. Traced wires from battery to where they enter the trailer.
Old 06-08-2014, 03:37 PM   #6
RSchleder's Avatar
The "switch" is typically a metal electronics box located adjacent to the converter. find your converter and you'll find the electronic power switch!
Old 06-08-2014, 04:26 PM   #7
ok, ill keep looking. i took a multi meter to the battery. it gave me a reading of .01-.03. what does that mean? i tested the meter with 2 other car batteries to make sure it was working properly, and it was.
Old 06-08-2014, 04:31 PM   #8
Ford Idaho's Avatar
Is the meter set to DC or AC?
For a battery it should be set to DC.
Old 06-08-2014, 04:52 PM   #9
dc. i unhooked the battery and tested still got nothing. plugged in the trailer to power, tested the cables running to the battery got nothing. .02
Old 06-08-2014, 08:26 PM   #10
RSchleder's Avatar
Starting to sound like the battery is "toast". If possible, replace your current battery in with a different battery (even if you have to borrow one from your car) and see what happins. If all works as designed with the replacement battery, you have a bad one in the RV and it will need to be replaced with a new deep cycle.
PS- you'll also need to be sure your are getting a charge current to the battery when plugged into a land line or the tow vehicle.
battery, charging
