Originally Posted by wannabeowner
"1) what is the most simple way to monitor the battery so that i dont drain them down past 50%? "
I'd also like to know if there's a simple, relatively accurate way to do this. We intend to get a Trimetic or Victron monitor in the future, but it won't happen this summer. Is there another, reliable way to monitor battery usage while dry camping?
As I posted, I installed a voltmeter just inside the A-frame entrance door. When dry camping, the voltmeter provides an estimate of SOC. When battery voltage drops to 12.1, the battery is at approximately 50%.
Contrary to what some have posted, modest loads on a battery in decent condition do NOT impact the voltage reading significantly. In my experiment with the propane/CO detector on, the Fantastic Fan on, and any other parasitic loads on, the battery voltage dropped 0.02 volts (repeated) compared to the no-load condition. And because the load lowers the voltage, I would reach 12.1V when the battery was actually slightly better than 50%.
The 50% is not hard and fast, either. As the SOC goes lower, the number of discharge/recharge cycles the battery will tolerate before it is toast gets smaller. If you drop to 40% SOC, you get fewer discharge/recharge cycles. If you always stay above 70% SOC, you get a longer battery life - at the cost of less usable capacity. 50% SOC is simply a commonly used trade-off point between usable capacity and battery life.
These SOC vs battery cycle curves vary by the type of battery. The typical "marine deep-cycle" is actually a combination starting and deep-cycle battery. It will maybe do 100 cycles at 50%, and drops off rapidly below 50%. You car's starting battery only needs 2-3 cycles below 50% SOC, and it is toast. A Surette deep cycle can do at least 500 cycles at 50%. Gel and lithium batteries have completely different curves.
hope this helps
Fred W
2014 Rockwood A122 A-frame with 2 6V GC-2 batteries (Interstate/Costco)
