Old 08-20-2015, 10:08 AM   #11
Originally Posted by TURBS View Post
You'll still only have 30 amps but you may have more volts!
TURBS
08 duramax tuned n modded
2011 32bhok Sabre
2015 camping "24 nights"
Yes Turbs you're right, thought about that after posting. Along with the fact that if you are low on voltage to begin with (busy campgrounds) you will use more amps.
2016 Ford F250 XLT 4X4 6.2L
Hensley Arrow
Nights camping in 2017: 20 nights
Miles traveled in 2017: 1,530
uhduh camping is online now   Reply With Quote
Old 08-20-2015, 10:09 AM   #12
TURBS's Avatar
Indeed!
TURBS
2011 32bhok Sabre
Old 08-20-2015, 04:50 PM   #13
Why do you only have 30 amps if you are plugged into a 50 receptacle?
harpplayer is offline   Reply With Quote
Old 08-20-2015, 05:05 PM   #14
Tom48's Avatar
Still, be sure inverter if any is off. Water heater is on gas only as opposed to gas and electric. Be sure with ac on, you take frig off AUTO and on to gas only.. Then there is always GO LED but suspect if coach is new, it is likely already led. Clean connections and go for it. I am told that there are Two Grades of breakers. Some just breakers while some are designed to double as on/off switches. Parks ought to use the heavier duty cycle breaker/switches, but wind up using the cheaper breakers. I'm sayin---- just what I've been told.
Tom48 is offline   Reply With Quote
Old 08-20-2015, 05:07 PM   #15
You only use 1 leg of the 50 amp when you use a 50-30 adaptor.
Old 08-20-2015, 05:08 PM   #16
Tom48's Avatar
You might have 50 but your onboard panel is only breakered and wired for 30. So 30 is your limit. Just might not blow the 50 amp pole breaker. The load will shift to YOUR breaker box.
Old 08-20-2015, 05:21 PM   #17
wmtire's Avatar
Using one leg of a 50 amp outlet, still can allow up to 50 amps from the campground outlet, thru your power cord, to your electrical distribution panel inside the RV.
From the distribution panel forward, all of your circuits are "hopefully" protected by the RV's main 30 amp breaker.
As Tom said, if you overload the RV's circuit(s), then you hope the RV main 30 amp will trip.......since from that point back to campground pedestal will be 50 amp capable and will not trip the campground pedestal when you go over 30 amps and under 50 amps.
Your RV cord is going to be the weak link here. It's rated for 30 amps still. Normally it would be protected by the campground pedestal 30 amp breaker, but since you are now plugged into a 50 amp outlet, then it could conceivably burn up if pulling over 30 amps for very long thru it.
However, for that to happen, you would also have to be pulling over 30 amps thru your RV's distribution panel also, and it's main 30 amp breaker should trip. It could go bad or not trip fast enough, but this is doubtful....but could happen.
If you limit yourself to what you usually use in a 30 amp scenario, then you shouldn't really be pulling more than 30 amps thru the cord, even when hooked to a 50 amp capable outlet.
Instead of having two 30 amp circuit breakers (one inside for the RV, and the other outside for the cord and/or RV) to protect it all, you are just going to be relying totally on the one 30 amp main breaker inside your RV's electrical distribution panel. Bad things could happen, but don't know if I have heard of it actually occurring.
2011 Flagstaff 831 RLBSS
Iíve lost my scapegoat.
Old 08-20-2015, 05:27 PM   #18
Flybob's Avatar
You need to monitor the current draw when the AC starts, especially a compressor restart while running. The restart of the compressor it the most demanding.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 08-20-2015, 05:53 PM   #19
jammer 16
We had a similar problem and it was the electric element in the hot water heater. Fixing it cost 30 finding it. Cost 200
rlschurman is offline   Reply With Quote
Old 08-20-2015, 06:05 PM   #20
Tom48's Avatar
Before you pay the dealer, always come to the forum. Half a dozen pointers and three or four of them are going to be correct and try to save you that $200
breaker
