1. Can I install the battery charger leads to the battery permanently, so I can charge it while still connected to the trailer? (Or do I need to disconnect the battery from the TT while it's charging?
Yes > if you are using a computer controlled maintainer I suggest you turn it off prior to connecting RV to shore power.
2. Is the TT battery charging from the TV while we're traveling down the road?
Technically yes, but unless you have upgraded wiring in TV you will most likely keep a fully charged battery charged while traveling. You will not be able to recharge a depleted battery on a normal driving day.
3. I know it's been answered before, but for clarity, if I leave the TT plugged in to my TV while camping, does it drain my TV battery?
Depends. Some TVs have a relay in the fuse block that disconnects the 12V aux line when the ignition is off. If you do not have a relay, the RV can drain the TV battery.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
