I will get a pic tomorrow, but to describe what I have in the battery compartment, I have two deep cycle 12v batteries.
The batteries are connected to each other with large cables, positive to positive, and negative to negative.
There are two coach cables, negative to negative of the left battery, positive to positive of the right battery.
There are two "Inverter" cables, negative to negative of the left battery, positive to positive of the right battery.
There are two "solar" cables, negative to negative of left battery, positive to positive of right battery.
I have not moved any cables, these are the way they were when we got the fifth wheel last April.
All 12v accessories, including the inverter, has been working fine. I am confused, because everything I see tells me I should see between 11.8 and 13.2 volts...
