Old 07-31-2016, 04:48 PM   #1
No 110 power - please help
Just pulled in and set up but not getting any 110 to our Flagstaff 8528IKWS fifth wheel. House battery has shown signs of getting weak and I am going to replace but will/should that affect the 110?
I am running the 30 amp service thru a surge protector that shows good power.
Checked all fuses and circuit breakers... not sure how to troubleshoot from here.
Any help appreciated!
Darrell & Kathy
2013 Flagstaff 8528IKWS 5er
2013 Ford F250 6.7 Diesel
B&W Companion Slider
wdw0528 is offline   Reply With Quote
Old 07-31-2016, 04:51 PM   #2
SeaDog's Avatar
The first are you getting 12V from the converter? second disconnect your shore power cord and test at the plug that goes into the rig to ensure power is making it to the rig. with circuit breakers they can look on and are not cycle them turn to off wait a few seconds and then back to on. let us know what you find
Retired Navy
Jake my sidekick (yellow Lab)
2006 F350 6.0
2016 Flagstaff 26 FKWS
AF&AM of Idaho
Old 07-31-2016, 05:10 PM   #3
Flybob's Avatar
What surge protector? When you say shows good power what is indicator ( led/ meter)? Is the surge protector good? Try without surge protector if pedestal voltage and phase is correct.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 65W solar panels
Old 07-31-2016, 05:47 PM   #4
Update - although the surge protector (progressive industries) showed a good LED reading and voltage it was apparently not allowing it to flow thru (not sure why) but once removed I am in business.
Just no surge protection now.
Thanks for the quick replies!
Darrell & Kathy
Old 07-31-2016, 05:54 PM   #5
SeaDog's Avatar
glad you figured it out and thanks for letting us know
Retired Navy
2006 F350 6.0
AF&AM of Idaho
Old 07-31-2016, 06:12 PM   #6
i had a problem once with power not going through a progressive industries energy system. the power readings showed that everything was good, yet no power to the trailer. it turns out the power readings (voltage and amperage) are taken from the input side of the device. in my case there was a piece of plastic inside the unit that kept the contactors from closing to route power to the output side.
CHICKDOE is offline   Reply With Quote
Old 07-31-2016, 07:20 PM   #7
HONDAMAN174's Avatar
I would get that looked at pronto. Don't want to be without protection!
2014 Evo 2850 "Woodstock"
2011 Toyota Tundra "Clifford"
Just glad to get away
Old 07-31-2016, 07:36 PM   #8
raspivey's Avatar
I find it interesting that PI finds it necessary to include instructions to remove the cover on the contactors to make sure no plastic pieces fell in preventing them from opening in the event of an issue. At least, my hardwired 50A had those instructions. Sounds like a QC issue to me...having said that, mine didn't have that problem but, I'm guessing, a number have.
2012 Chevy Tahoe LTZ - HD tow package
Old 07-31-2016, 08:36 PM   #9
here's what happened about the plastic piece. I had a dealership install the ems. to do so they installed the ends of the heavy electrical cables into the terminals in the ems. they installed one of the cables deeper than it should have been. there is a plastic shield with fingers on it that goes over the contactors and is supposed to protect the contactors from having the cable pushed in too far and allowing the cable to touch the contactor. in my case I guess the installer just pushed the cable in and he broke the plastic protection finger. it then lodged in one of the contactors and prevented it from closing. the tech that installed the ems told me he plugged the unit into 50 amp power and got good readings from the ems box. however, when i went to use it i could not get any power out on one leg. i called progressive and they had me disassemble the covers and we got the broken finger out and then i got full power. they sent a new shield. i backed the power cable out a bit, installed the new shield and all is well. in talking to the progressive tech guy he said this happens. they were very nice and responsive!!! note - this is where i learned that all readings from the ems are taken from the input side of the unit. this is where all the monitoring is taking place.
Old 07-31-2016, 10:24 PM   #10
power
