Old 09-19-2015, 07:48 PM   #1
No 120 v
Hooked up, ac , refer work fine
No tv power or receptacle power
Could this be the 50 amp plug?
MBeech is offline   Reply With Quote
Old 09-19-2015, 08:21 PM   #2
Have you checked for a tripped GFCI. Usually near kitchen or bathroom it has to buttons in middle "test and reset".
2016 Ford F250 XLT 4X4 6.2L
Hensley Arrow
Nights camping in 2017: 20 nights
Miles traveled in 2017: 1,530
uhduh camping is offline   Reply With Quote
Old 09-19-2015, 09:11 PM   #3
Kitchen gfi does not trip
Other two in bath trip and reset
Kitchen gfi seems to do nothing when attempting to trip and reset
Mike
2015 Cedar Creek 38fb2
Mike.............
Orange Beach Al
Mike & Sharon 2011 Cedar Creek 30RL
Dodge 3500 Mega Cab
Old 09-19-2015, 09:17 PM   #4
swmelton's Avatar
What you're describing is only "True" 120v equipment is working and nothing that uses 12v or inverted power is working. Points to the inverter not working or not getting power. hHeck the fuses in that area
Scott & Val
West Virginia
2018 3500HD Crewcab Diesel
2018 Chaparral 360IBL
Retired Air Force
swmelton is offline   Reply With Quote
Old 09-19-2015, 09:23 PM   #5
Ford Idaho's Avatar
You need to start with the power source, correct voltage and amperage?
If so then start testing towards your unit and verify volts and amps as you move along.
Old 09-19-2015, 09:28 PM   #6
Phat Phrog Stunt Crew
elind's Avatar
Check the circuit breakers in the RV and pedestal. It could be one side of the 50 amp power is tripped. There are two hot wires coming into the RV and one side is dead. Do you have a 30 to 50 dogbone adapter? If you do plug it in to the 30 amp on the pedestal.
2014 Wildcat 327ck
elind is offline   Reply With Quote
Old 09-19-2015, 09:36 PM   #7
northstar1960's Avatar
Mike
if the gfi does nothing it's a common short ! check the breakers and then where you're hook up ,may be a bad outlet
northstar1960 is offline   Reply With Quote
Old 09-19-2015, 09:44 PM   #8
Great
I will check for 120 volts on both sides of the outlet
I did find I have one 110v plug working on opposite wall from TV
Seems odd both tvs being affected while micro and refer and both ac are ok
Mike.............
Orange Beach Al
Dodge 3500 Mega Cab
Old 09-19-2015, 10:17 PM   #9
I just had a issue like yours, the outside GFI on the outside wouldn't trip or test, the receptacle above the sofa and the one by the front television all showed open neutral. All the other receptacles worked fine. Turns out it was the receptacle powering the fridge was defective and all the others were in line from this.
2014 Forester 3051s
2016 Nissan Pathfinder SL
2012 Sonic toad
wana65stang is offline   Reply With Quote
Old 09-20-2015, 05:56 AM   #10
It could be a bad gfi recept. Usually if it won't reset or trip that means there is no power going to it..
If you've checked all the breakers you might have to pull it out and test for voltage coming in..
Keep us posted..
Joe
meganjoe is offline   Reply With Quote
