Old 06-09-2013, 07:39 PM   #41
VinceU's Avatar
Originally Posted by BarryD0706
So how did you ever measure 12v at the breaker with you voltmeter then?
Both sides would be hot, "just no plac to go!"
Old 06-09-2013, 07:44 PM   #42
Originally Posted by VinceU View Post
Both sides would be hot, "just no place to go!"
Got it. Thanks. I was thinking it was coming from the battery.
Congrats on solving the biggest mystery of the month!
Old 06-09-2013, 07:47 PM   #43
TURBS's Avatar
X2
Old 06-09-2013, 09:26 PM   #44
Here's the set-up:
There are supposed to be two red battery cables connected to the right side post of the small breaker. One comes directly from the battery. The other is the end that goes straight to the distributor. It connects to the right side terminal post also but bypasses the wiring in the junction box. It was tucked up behind a black cable about 3/4" in diameter, the end out of sight. On initial inspection, you would see the red cable going to the small breaker and the red one with the end tucked out of sight and assume it was going on toward the distributor.
It's almost like someone deliberately hid the cable end that goes directly from the right side of the small breaker to the distributor.
wyoman is offline   Reply With Quote
Old 06-09-2013, 09:53 PM   #45
VinceU's Avatar
Originally Posted by wyoman View Post
Here's the set-up:
Like a Monday car eh?
