Old 04-24-2016, 07:01 PM   #1
Question No 12V from battery
Strange symptoms. Not sure what do do next.
Background: camping last weekend, always on shore power.
- Put TT in storage Monday. Inadvertently left a light on inside (2 12V bulbs). Got it out the following Friday, and noticed light was on -- quite dim. Turned it off, of course.
- Connected to shore power. Thought battery was charging (power distribution fan cycled on for a bit).
- Disconnected from shore power. DC bus dead -- no lights, level monitor out, etc.
- Removed batteries (2x6V in series) and charged them using external charger. They seemed to take the charge OK.
- Reinstalled batteries. DC bus still dead.
- Examined power distribution center (WFCO WF-890). All circuit breakers good.
- Checked all fuses visually, including reverse-polarity fuses and the unlabeled 30ADC fuse in position 11. All looked good.
- Checked battery with voltmeter: each at 6V individually, total at 12V.
We leave on a long trip in two days; planning only to stop in places with shore power. I intend to disconnect the batteries (they're not doing any good) for now.
Does anyone have any ideas of what to do next? Thanks much in advance.
KellyG is offline   Reply With Quote
Old 04-24-2016, 07:46 PM   #2
Head Rambler
Did you check the fuse with a light or meter and not just visually?
Most setups have a circuit breaker between the batteries and the converter/power center, have you checked to see if those are tripped?
Gotta go campin!
Old 04-24-2016, 07:59 PM   #3
As Bama Rambler stated, check the circuit breaker that is inline from the batteries. Seeing as the batteries were so discharged the breaker more than likely tripped because of the high current the converter was trying to put into the batteries.
2007 Surveyor SV230
- 200 Watts Solar/MPPT Controller - 230 AH Battery Bank - 600 watt PSW Inverter - (2) 2000 watt Inverter Generators - LED Lighting
Boon Docking 99% of the time.
2009 F150 - 5.4 Litre - Tow Package
boondocking is offline   Reply With Quote
Old 04-24-2016, 08:03 PM   #4
Flybob's Avatar
Pull the two large fuses and check them with a meter. When you try to charge a deeply discharged battery with the convertor, the current can rise ( will activate converter fan) to a level that will blow the uses or trip the 12V breaker. Also do not disconnect the batteries. If you tow with the batteries disconnected, you will not have power to activate the brakes should the TT disconnect.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 04-24-2016, 08:46 PM   #5
Thanks much for the quick help!
- my voltmeter/continuity tester failed; getting a new one tomorrow
-I did not see a circuit breaker for between the battery and distribution center. It makes sense that there is one, but where??? (We have a Shasta Oasis.)
- I'm faierly sure the reverse polarity fuses are OK, since the AC-to-DC converter is able to power the DC bus components.
- I'll definitely hook up the battery: totally forgot about the safety brakes!
The circuit breaker--if I can find it--sounds like a good candidate.
Thanks again.
Old 04-24-2016, 08:59 PM   #6
HONDAMAN174's Avatar
Follow the positive cable from the batteries back to the converter. Usually is is underneath the unit and really close to the front.
2014 Evo 2850 "Woodstock"
2011 Toyota Tundra "Clifford"
Just glad to get away
Old 04-24-2016, 09:05 PM   #7
I also doubt the reverse polarity fuses are shot, because the converter is a 45 amp and the those fuses together are 60 amp.
The circuit breaker should be very close the the batteries. Follow the battery cable from the box to under the TT. The breaker should be attached to the frame very close to the batteries.
2007 Surveyor SV230
Old 04-24-2016, 10:22 PM   #8
Thanks very much, hondaman174 & boondocking.
I didn't do a hand trace of the battery cable, but will do so tomorrow. I don't recall anything from other visits underneath the trailer. :-) There is nothing within six feet of the box in any event.
The circuit breaker is attached to the frame? What protects it from road grime?
BTW, the reverse-polarity fuses were 40A each!
Old 04-25-2016, 12:04 AM   #9
My circuit breaker is attached to the frame. It is an enclosed unit so it is protected from road grime. Look for something similar to this.
I think your 40 amp fuses should be OK, mine are 30's.
2007 Surveyor SV230
Old 04-25-2016, 08:28 AM   #10
Disassembly?
Thanks for the picture. I guess it has to be disassembeled to reset? I'll be looking for mine in a few hours, over lunch break from work.
battery
