My 02 class A diesel pusher's living room slide does not have any 12v power. The lights flickered one evening and did not work the next day. I have checked the fuses and the wiring going to the slide....nothing! Also, the inside tanks, LP
[QUOTE="Mrgary"]My 02 class A diesel pusher's living room slide does not have any 12v power. The lights flickered one evening and did not work the next day. I have checked the fuses and the wiring going to the slide....nothing! Also, the inside tanks, LP indicator lights and water pump switch are not functioning.
Any help would be appreciated!
Gary R
[QUOTE="Mrgary"]My 02 class A diesel pusher's living room slide does not have any 12v power. The lights flickered one evening and did not work the next day. I have checked the fuses and the wiring going to the slide....nothing! Also, the inside tanks, LP, light indicators and water pump switch do not function.
HELP!!!!!
GARY
If, as you say, the wires and fuse are intact, then it sounds like the slide lost it's ground. Try jumping the metal slide frame to a good chassis ground, and see if the lights come on.
Fire Instructor
2022 Coachmen Leprechaun 319MB
2022 Ford Ranger toad
Thank you for responding to my problem.
Grounding the slide did not help. I have an audible continuity checker and it beeps when I touch one to the slide and one to the chassis. I even attached battery jumper cables to the slide and chassis
I feel that it must be a loose connection as all other 12v lights and fans work. There is no 12v power at all in the slide and no power to the tank info panel and water pump switch
Any other suggestions?
