Have power from pole to outside plug on rig....aka shore cord good....power on. But no power to fuse box whatsoever. All breakers and fuses are good including those behind the fuse box/inverter box. Anny ideas????? HELPPPPPPP
Not sure if this is the cause but my Flagstaff has a 30 amp that is up near the tongue of the trailer, on the frame. For some reason when it goes I get nothing throughout the trailer.
Adding to Turbs' idea. The loose connection could be at the main breaker as well. Check both ends of the power cable inside the RV. Check the neutrals too.
Gotta go campin!
