10-10-2017, 08:56 PM
RV Mobile Repair
No brakes on trailer!
We have a 2017 Surveyor 251RKS and the brakes suddenly quit working. I thought it might be the TV Prodigy P2 brake controller but I measure zero volts at the plug and with the brake peddle down it measures 4.8VDC. I called the Tekonsha help line and they said that those voltages are correct.
When I press the TV brake peddle, all I hear is a loud buzz from the trailer axle and nothing happens - no brakes apply at all.
Anybody have any ideas?
Joe and Jodi
2014 Chevy Silverado w/tow package
2017 Forest River Surveyor 251RKS
10-10-2017, 08:59 PM
Sounds like they need adjusting.
10-10-2017, 09:06 PM
RV Mobile Repair
merlinhomeauto - could all 4 wheels be that far out of adjustment with only 200 miles and 6 months old?
Joe and Jodi
10-10-2017, 09:14 PM
I'd pull 'em off and take a look. True, they might need adjusting, but they wouldn't just stop working suddenly. Could be several things. Sounds like a power problem if they buzz but don't apply. So check it at the 7way plug and before the magnets also. Check the grounds for corrosion or looseness. Good luck!
Scott and Liz - Southern NM
2007 Chevy 2500HD Duramax
10-10-2017, 09:22 PM
RV Mobile Repair
Guess I'll pull one apart tomorrow to see what's up . . .
Thanks guys, I'll let you know what I find!
Joe and Jodi
10-10-2017, 09:38 PM
My breakaway switch melted. (Probably due to a body shop mis-wiring from a rear ender on my TV in January. Owner sweared it was wired correctly and tested it on his boat trailer). Son and I found the wires were off by one clock click. When we got that straightened out the trailer breaks still didn't work. I pulled the breakaway cable and the plastic separator was melted. Try pulling the cable out of yours.
2017 GMC Yukon
2018 Roo 23 ikss
10-11-2017, 10:23 AM
The magnets buzzing are pretty normal, but it shouldn't be very loud.
I think pulling the hubs and inspecting them is the best thing to do.
Gotta go campin!
10-11-2017, 01:13 PM
Unless the OP is experienced in setting /adjusting brakes, he is best advised to go to the dealer, explain this is a safety item, not a luxury. Insist they check them and adjust or fix on the spot. It is within warranty I assume. If they say we can't get you in, call the manufacturer and insist they cover your costs at a brake shop for repair. Trailer brakes are fairly simple, but if they are not working they are useless, and dangerous. It's time to play hardball with the dealer / manufacturer. Grab a bat, you're up.
John
2019 Ram 3500 CC 4X4 Cummins 6.7l
2020 Fuzion 369 toy hauler
10-11-2017, 01:49 PM
With the tow vehicle’s brakes fully engaged, having 4.8 VDC between pins 1 and 2 on your tow vehicle’s 7-pin trailer connector is too low unless the controller is doing something fancy with the open brake voltage. Perhaps the controller's gain is too low. If that’s the case, then turn up your controller gain.
I recommend you check the tow vehicle’s voltage between pins 1 and 2 again with the breaks fully applied and the brake controller’s gain set to maximum. I would expect over 12 VDC.
One way to see if the problem is with the brakes would be to pull the brakeaway switch and try a short pull test of 3 or 4 feet. If you have significant braking from a dead stop then the brakes themselves are fine. Just don’t keep the brakeaway switch pulled for more than a minute or so as it can overheat.
Dexter has a procedure for troubleshooting your brakes, including how to burnish the brake shoes on new brakes.
https://www.dexteraxle.com/docs/defa....pdf?sfvrsn=18
2015 Wildcat 282 RKX
2011 F350 Lariat, 6.7 L. Diesel, 8 ft., SRW, Reese R20
10-11-2017, 04:08 PM
Sounds to me like the unit is still under warranty. Would it not be best to bring it to the dealer or a dealer and have it fixed under the warranty?
10-11-2017, 04:52 PM
If it's still under warranty take it to the dealer.
Cedar Creek Silverback 33IK
Donald&Casey cairn terrier
10-11-2017, 04:57 PM
I'm not familiar with your controller but some controllers use inertia/momentum of a moving vehicle to apply the brakes when motion is reduced. Pressing the pedal when stationary does not fully apply the brakes. Have you tried pulling the breakaway pin? This would apply full braking pressure with a charged battery.
Cedar Creek Lake, Texas
2019 Keystone Loredo 290SRL
Andersen hitch
10-11-2017, 05:25 PM
X2, well put!
10-11-2017, 05:44 PM
Need to check the voltage while applying the manual lever at a very high gain. Then you can actually get the full voltage from the brake controller. Then you can try the break away lever.
You can also do an ohm test . Each magnet is 3.0 to 3.8 ohms. With 4 magnets in parallel, it will be very low...less than an ohm. If you measure something higher, you have an open to one or more magnets.
10-12-2017, 10:13 AM
If you have a friend that has a truck with the right hitch or you can put your hitch on their truck and test it, several years ago I had the same problem with my travel trailer, I took it back to the dealer they used their truck and the brakes worked fine, hooked it up a friends truck and they worked fine, I found corrosion on the back side of the 7 pin on my truck, cleaned up the connections and applied some dielectric grease (several times a year), problem solved.
11-14-2017, 01:40 AM
RV Mobile Repair
Found the problem was the brake controller. It had good voltage but under load it dropped to 9 volts. Replaced it and all is fine!
Thanks for the help everyone 😀
Joe and Jodi
11-14-2017, 09:52 AM
Thanks for getting back to us with the cause.
2012 Rockwood Ultra-Lite 2701SS, Goodyear Endurance LRD, ProPride 3P 1400 hitch
2013 F-150 FX4 7700# GVWR SuperCrew 3.5L EcoBoost 157" WB Max Tow 3.73:1
John, Dawn and Emily... and Bella the camping kitty
visit our website at www.restcure.ca
11-14-2017, 12:45 PM
Glad you got it figured out and came back and let us know what it was.
Can you tell us what the controller was?
Gotta go campin!
11-14-2017, 02:27 PM
See Post #1...
11-14-2017, 02:30 PM
RV Mobile Repair
The manufacturer replaced the 4 year old Prodigy controller at no charge. Good customer service!
Joe and Jodi
