Well, the main problem at the campsite was a wonky 25-foot coax cable we used to connect to the pedestal. I never checked the cable before we left and when
Scrapper mentioned crimped connections, I checked the connecting cable today. Turns out the center lead on one end was rather short and, when hooked to the tester, I could bend the cable and cause a a flip-flop between a short/open condition and a pass condition.
Additionally, I found out why my testing went awry. It appears that the circuit board interferes with the loopback signal used by the coax tester. This is the reason I was getting a "short" status when using the tester with the brown "CABLE" cable attached to the RV-7542 and the red cap on the outdoor RG6 connector.
Sadly, my neighbor's old DVD did not have a coax output so I had to scrounge around in the basement for a signal generator. I found my sons' electronics storage box and created my own NES-Tronix Signal Generator:
Lo and behold, I got Zelda on the TV:
With everything back in working order, I decided it was time to understand the behavior of the RV-7542 and the TV's channel scanning. After all, why spend only 7-hours trying to sort this problem? With 25+ digital OTA stations at my location, I wanted to see the results of the scanning process based on the selection of the TV's channel scan source setting. Here's what I found:
Test 1
RV-7542 setting: Power on
TV input setting: Antenna
Channel scan source: Antenna
Result:
- Digital signals found = 28 (OTA) but almost 10 were a bit "iffy" without rotating the antenna
- Analog signals found: 1 (NES-Tronix)
Test 2
RV-7542 setting: Power off
Channel scan source setting: Antenna
Result:
- Digital signals found = 6 (OTA) but 2-3 were a bit "iffy" without rotating the antenna
Test 3
Channel scan source setting: Wall (Cable)
Result:
- Digital signals found = 0 (OTA)
So, I'm drawing the following conclusions from this mis-adventure:
- Our problem at the campsite was (a) abundant ignorance and (b) not verifying the connecting cable before leaving;
- I did not understand that the Klein coax tester would be flummoxed by the RV-7542 circuit board;
- The Rayzar's antenna amplifier really does a very nice job of bringing in more OTA stations;
- The (Insignia) TV's channel scan depends on the setting of its scan source setting;
- Scanning using the "Antenna" as the scan source setting "discovers" both OTA AND cable sources;
- Scanning using the "Wall (Cable)" as the scan source setting "discovers" only cable sources;
- I'm still not springing for satellite!
Thanks to all for helping me through this issue. It is only through the wisdom of others that one realizes how much they DON'T know!
